Willing to pay $50 to whom finds my problem
Old Dec 28, 2007 | 11:31 AM
  #41
goldtooth's Avatar
It did not throw codes. I took it to the transmission shop on Irving Park and Melvina, cuz I thought surely it had to be the transmission. To my amusement, they told me they disconnected the exhaust from the engine and it was running perfectly fine. I said okay, thanks, and drove the car back by my house, which is less than 5 min away. Took off the exhaust the next day; started it and sure enough it was running fine. I could rev it to redline with ease. At that time my Budget Ypipe had just come in and I put it on. I also had my dad take the cat to his work since he has access to pressurized air and cleaned out the sand clog, but we did not gut it, some of the honeycombs are still in there. Anyhoo, after a few days after I had the O2 bung welded in the test pipe that came with the Ypipe, I put in the test pipe for tuning reasons. Since then, never had that problem. Good luck with yours. If you need anything else, let me know.
Old Dec 28, 2007 | 12:18 PM
  #42
97SMG's Avatar
Cat must be completely clogged for that to happen....... I'll try to get to that this weekend........Hopefully the snow will go away.
Old Dec 28, 2007 | 01:15 PM
  #43
goldtooth's Avatar
Damn snow, I was about to start looking around the junkyards for a steering knuckle, but along came this crap, caught me by surprise and im pissed. lol
Old Dec 28, 2007 | 01:39 PM
  #44
black_maxed95's Avatar
http://weather.yahoo.com/forecast/USIL0225.html
no more suprises
Old Dec 28, 2007 | 02:03 PM
  #45
goldtooth's Avatar
hah, i know, but I came home from work it was nice and dry, I take a 1.5 hour nap, wake up and its ****tting everywhere. lol ok enough about that
Old Dec 28, 2007 | 02:32 PM
  #46
91parkave's Avatar
if it turns out to be the cat then i need that 50...lol
Old Dec 28, 2007 | 02:38 PM
  #47
97SMG's Avatar
Sure.........I just wanted to hear it from personal experience more than anything. It sounds like the problem is similar but yet a bit different too.
Old Dec 28, 2007 | 07:04 PM
  #48
jvckustumz's Avatar
have you checked your fuel pump in the tank ti make sure it is putting out right?? i had to replace mine just today because my car would stall when i pressed the gas alittle bit but be fine later then it kept getting worse and finally just crapped out on me lol
Old Dec 29, 2007 | 04:43 AM
  #49
97SMG's Avatar
Yeap, tried a fuel pump from a working car...........It's all in the first post.
Just to weigh out my problems. Is there any that has experienced a stall issue related to an UDP??
Old Dec 29, 2007 | 05:07 AM
  #50
goldtooth's Avatar
If you already swapped out the engine, but like you said you kept the old UDP. So its either gotta be the UDP or the exhaust, but dont mind me, Im just thinking logically back at step one.
Old Dec 29, 2007 | 08:33 PM
  #51
Keep'emclean's Avatar
EricJ
May be a dumb suggestion but did you make sure everything has a good ground? I am not sure if this would relate to your specific problem but did you ground your starter and trans with a good ground? This is a common problem.
Old Dec 29, 2007 | 11:43 PM
  #52
00SEMAX19's Avatar
Did you change the flywheel? A Crank position sensor can deffinatley cause issues. Not a max but I swapped an engine on a kia and the new engine didn't have the timing ring on the flywheel of the engine we purchased and the car ran but had very bad studdering and missfire but no codes. I had to remove the tranny and swap the flywheel. Other people have had damaged flywheels causing similar issues. Good luck and keep your 50
tsi6001
Oct 3, 2022 10:23 PM
soloist3
Sep 2, 2015 12:59 PM
kirkhilles
Aug 8, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
BassAddictJ
Aug 4, 2015 11:38 AM
