Alternative ALTERNATOR
Old Dec 26, 2007 | 05:33 PM
oVeRdOsE's Avatar
Hi,
I went to the red line because I was stuck in the snow, and my battery light cames on.
Some times, I disappear for 4-5 sec and my voltage 's stable , around 13.4 volts.
My alternator dont work for the most of the time : voltage under 12.
I want to know, is it the alternator itself or a fuse or a electric problem???
Or, where can I get a good alternator, what are my choices?
(I have a spiral grid battery and a heavy sound system)
Old Dec 26, 2007 | 06:33 PM
firemedic3426's Avatar
Startin' Out
If you have a heavy sound system you might want to think about capacitors and then an upgraded alternator. If you go to a alternator shop (not an auto parts store but an acutal shop where they rebuild alternators) you can get one to whatever amp you desire. Just a word to the wise if you go too high you will need an aftermarket voltage regulator to handle the bump.
Old Dec 26, 2007 | 07:44 PM
dgeesaman's Avatar
Maintenance Monster
Originally Posted by oVeRdOsE
Hi,
The fact that you mention running the engine to red line and being stuck in snow in the same sentence suggests a lot about how you got stuck.
As for upgrading the alternator, I would get a good replacement if yours is bad and get a good battery with a high cold cranking amp rating. Next time you rev the crap out of it when trying to get more stuck, turn down the stereo.
Dave
Old Dec 26, 2007 | 08:11 PM
oVeRdOsE's Avatar
Dave
Mmm, hard to go slow when you have a feet of snow on the road. I want to get a good speed to dont get stock in the middle of the road.
The fact is, the alternator 's old, at 6500 rpm , its not supposed to burn.
By heavy sound systeme, I mean 900 w rms in the total of the amps. So I dont ride with the volume to the max. It was a suggestion, because I want a good alternator.
For my battery, dont worry, I got a 1 year old yellow top, and I never drain it.
So the suggestions? OEM? I guess...
Old Dec 27, 2007 | 10:28 AM
BeZerK2112's Avatar
Consider something with a lifetime warranty. The shop I worked at always bought things from checker. They seam to do rather well and if it ever goes out.... FREE alternator!
TallTom
57
Oct 14, 2025 05:16 PM
