Top Speeds in Each Gear
Old Oct 25, 2001 | 07:38 PM
WaarrEagle's Avatar
What is the top speed for each gear? I remember 1st is 35 and I thought 2nd was 85 but when I tell my friends this they say I am crazy. I tried searching but nothing came up. So what is the top speed in 2nd and 3rd? I'm an auto.
Old Oct 25, 2001 | 07:51 PM
SuDZ's Avatar
Re: Top Speeds in Each Gear
No way is it 85 it is like 63. On most cars it is always about that. It is for faster 0 -60 times so you dont have to make a 2 to 3 shift. You are talking about a 5 speed right? If not i am not sure then. But I know about 5 speeds for sure.
SuDZ
Old Oct 25, 2001 | 08:04 PM
black96se's Avatar
Did a little math and here are the top speeds in each gear (I know you're not going to go 260 in 5th, but if you could hit redline you would )
1st--3.290 63 km/h 39 mph
2nd--1.850 112 km/h 70 mph
3rd--1.272 164 km/h 102 mph
4th--0.950 219 km/h 136 mph
5th--0.800 260 km/h 162 mph
Old Oct 25, 2001 | 08:05 PM
KLoWnPR109's Avatar
He said that hes an auto. Did anyone read the Sport Compact Car where they did the article about the "conspiracy" over transmissions? It's like all cars are designed to shift from 2-3 around 62, thus making the 0-60 times quicker.
Old Oct 25, 2001 | 08:09 PM
Bags's Avatar
VG Ridah's Biatch Hoe
i am an auto and in 2nd i have been 75 and that was a little past redline.
in 3rd i have been to like 123/124 a little past 120 on my se gauge again above redline
Old Oct 25, 2001 | 08:25 PM
black96se's Avatar
2nd try.....
Damn my short attention span
OK, did a little more math and got these numbers:
1st--2.785 75 km/h 47 mph
2nd--1.545 136 km/h 84 mph
3rd--1.000 210 km/h 130 mph
4th--0.694 302 km/h 188 mph
If the gear ratios are correct (searched for them here), this should be right.
Old Oct 25, 2001 | 08:33 PM
WaarrEagle's Avatar
Re: 2nd try.....
Cany anyone verify this? I really don't think my 1st gear goes up to 47. But then that 84 is what I thought was 2nd gear's top speed. Does the tranny shift before these max speeds are reached? I will pay closer attention when I drive it tomorrow.
Old Oct 25, 2001 | 08:50 PM
Bags's Avatar
Re: Re: 2nd try.....
i got this out of the factory service manual
from d1 - d2 at full throttle the shift is at 38-43 mph
from d2 - d3 at full throttle the shift is at 70-75 mph
from d3 - d4 at full throttle the shift is at 110-115 mph
now you can override this buy keeping the shift lever in the selected gear until you want to change or hit the limiter.
Old Oct 25, 2001 | 09:13 PM
black96se's Avatar
Alright, that makes sense. Sorry, I don't know much about automatics, I've only driven one once (driver training - that was awful )
I just got those speeds according to rpms (used 6600), gear ratios, and tire circumfrence.
Old Oct 25, 2001 | 09:23 PM
ZXdude's Avatar
its in the owner's manual
jiaxima96's Avatar
My 96 owner's manual says with auto, at "1"(low gear): do not exceed 40 MPH, at "2"(second gear): do not exceed 73 MPH. It's on page 4-7
Old Oct 25, 2001 | 09:39 PM
WaarrEagle's Avatar
Ok, thanks for clearing that up everyone.
Old Oct 26, 2001 | 01:54 AM
norton2099's Avatar
Are all those top speeds going past the redline? I generally rev right up to the redline on occasion I pass it by a little bit.
These speeds are all right up to the redline
1st gear: 30 mph approx.
2nd gear: 60 mph approx.
3rd gear: 90 mph approx.
Give or take ±2 mph.
Old Oct 26, 2001 | 06:09 AM
SLC I30t's Avatar
I would like to see any of your maxs go 162mph on a stock engine. THat might be the gear ratio calculations, but I seriously doubt the max can go that fast. It doesn' have the power to do so. S/C maybe, NOS maybe. The aerodynamics of the car, I would have to do the math and I can't from where I am at. Would leave the at a terminal velocity in the 150's on a non-modified motor.
Old Oct 26, 2001 | 08:06 AM
NZ Max's Avatar
Yeah, my auto does 188mph...
Old Oct 26, 2001 | 09:11 AM
Sonic's Avatar
Having actually done this before (don't ask why), the numbers are pretty close to black96se's estimations.
1:46
2:84
3:122
4:Whatever you get up to, but I can't hit redline in 4th gear.
Old Oct 26, 2001 | 10:22 AM
SuDZ's Avatar
Thats why he said in theory it could.
SuDZ
Old Oct 26, 2001 | 10:52 AM
SLC I30t's Avatar
I guess those speeds are in an Auto-Medicsonic? But in theory would be a place with out gravity or air, right? I do have a redline question... is the rev limiter set off of my ECU or the needle? I hit it today, and it's at 6700-6800 rpms. I've been told that the limiter is set for 6500rpms. I'm just wondering if my Tach is off a little.
Old Oct 26, 2001 | 12:52 PM
Sonic's Avatar
1.)Those are automatics, and are the actual speeds at redline.
2.)Your tach is off. The first time I had my car dynoed, the guy doing it said I was the first car that he had seen in a long time with a dead accurate tachometer, most are off by about 200.
3.)The ECU should be limiting your RPMs.
Old Oct 26, 2001 | 01:10 PM
SuDZ's Avatar
What were your stats when you got Dyno'd?
SuDZ
Old Oct 26, 2001 | 01:18 PM
Sonic's Avatar
We don't talk about it in public, but everyone knows that I have one of the underpowered 4th gens. It's on the 4th gen forum and the NE forums in one of the Maxus threads, I'll have to find it.
Old Oct 26, 2001 | 01:21 PM
norton2099's Avatar
Originally posted by rOaD bEaSt
Because all what you said was excatly as my guage
I was talking about 5-Speed :]. Must be very different on Automatic cars. In any case I've gone around 140 before in 5th gear of course and it was just a little bit below the redline.
Old Oct 26, 2001 | 11:13 PM
black96se's Avatar
OK, I just worked out the speeds with math - it was only supposed to help and not be totally accurate. I am totally aware that a stock maxima cannot go 260 km/h (give me some credit). This is the equation I made - It should be correct, but if anyone finds anything wrong with it, please tell me. Obviously you can simplfy it, but it would be harder to figure out what i was doing. Hopefully I typed this up properly.....it's 2 in the morning now, gotta get some sleep
Old Oct 27, 2001 | 10:24 AM
n2oMike's Avatar
simplified...
mph = (rpm x tire diameter)/(overall gear ratio x 336)
To get the overall gear ratio, multiply the tranny ratio by the transaxle ratio. 3rd gear in an auto (4th being OD) is most always 1.00 Anyone know each gear ratio, and the transaxle ratio of the max?
Be aware that in automatics, converter slippage will make the engine spin a little faster than the car is actually going. (unless the car is equipped with a lock-up converter, and it is engaged)
Old Oct 27, 2001 | 10:30 AM
d_98SE's Avatar
Off-topic but did you know that in a lambo diablo you shift into second after 63 mph talk about raw power.
Old Oct 27, 2001 | 02:16 PM
black96se's Avatar
Thanks for simplifying it n20Mike, I was too tired last night
Manual
1st -- 3.290
2nd -- 1.850
3rd -- 1.272
4th -- 0.950
5th -- 0.800
Reverse -- 3.430
Final drive -- 3.823
Auto
1st -- 2.785
2nd -- 1.545
3rd -- 1.000
4th -- 0.694
Final drive - 3.789
Old Oct 27, 2001 | 04:50 PM
hlh0501's Avatar
in my auto, I would run 41mph in 1st, 82in 2nd, 115 in 3rd..
btw, whoever was talking about the auto conspiracy of shifting at 62mph, the mclaren f1 lm does too, but that is shifting out of 1st, into 2nd ! ! ! ! ! you could run interstate speed in 1st haha ! I love that.
James92SE
142
Jan 2, 2024 09:23 AM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
pjgreek
Sep 9, 2015 09:30 PM
