For those who have done the 5 speed swaps
Old Jan 1, 2008 | 02:59 PM
euromaxima's Avatar
Does anyone have pics of the engine after complete that show where you put the fluid resvior and even pics of the process, I have found the write up but can't tell much from the pics cause they are so small. did you have a cel issue after it. thanks
Brandon
Old Jan 1, 2008 | 03:00 PM
euromaxima's Avatar
Also If anyone with experience in this wants to donate some time and help me with it, It would be appreciated.
Old Jan 1, 2008 | 03:10 PM
mtrai760's Avatar
'Trynna' is not a word
What reserviour are you refering to?
Old Jan 1, 2008 | 03:55 PM
darklegend06's Avatar
5spd swap is pretty simple, but time consuming.
Old Jan 1, 2008 | 04:03 PM
ghostmax301's Avatar
i think hes talking about the master cylinder for the clutch... i could help you with the swap through the org if thats any help to you. Im sure you live too far for me to drive but as darklegend06 said, its time consuming.. took me about an entire day, striping the 5spd max, striping my auto, the reintalling the 5spd in my auto max.. I'd say the BIGGEST P.I.T.A is if your car or the donor car has ABS.. the brain for it is a bish to work around
Old Jan 1, 2008 | 04:13 PM
f550maranello2's Avatar
i wanted to take pics but i started working and i just didnt work out.. i would have had to have somebody there taking pics..
Old Jan 2, 2008 | 03:05 PM
Kevlo911's Avatar
Kevlo for President
Old Jan 2, 2008 | 03:46 PM
97SMG's Avatar
Brandon
You shouldn't have any CEL's other than maybe Park/ neutral switch and even then you can get rid of that.
Old Jan 2, 2008 | 06:38 PM
euromaxima's Avatar
Originally Posted by Kevlo911
do you have any more pics of the swap? thanks
Brandon
Old Jan 2, 2008 | 06:44 PM
JtzMax's Avatar
Whatchyou say?
you'll need a 5spd ECU to clear the CEL .... the auto has more electronics than the 5spd
nice Kevlo! when in doubt ... make it work!
Old Jan 2, 2008 | 06:59 PM
WOW kevlo that is one clean cut for the master cylinder hole.
Old Jan 2, 2008 | 07:14 PM
Kevlo911's Avatar
Kevlo for President
It was hard as fck, drill barely fits...
Check out the heat haha.
http://kevlo911.ic3donline.com/image...manwel%20swap/
all my images of the swap are there
Old Jan 2, 2008 | 08:36 PM
how did u fit a drill in there... ??
Old Jan 2, 2008 | 08:41 PM
Kevlo911's Avatar
Kevlo for President
From the inside, it's fun lol
Old Jan 2, 2008 | 08:55 PM
yea right man i couldn't fit with my wide shoulders.... i had to cut it from the other side...
Old Jan 3, 2008 | 07:13 AM
YOu should check my cut,
I drilled a small hole, and from there I worked my way out with those metal shavers to make the hole the master cylinder hole size. TOok me 4hours.
Old Jan 3, 2008 | 06:44 PM
chillin014's Avatar
i want to see what people used for spacers on the firewall with the clutch pedal. i feel like I put too many washers. i bought a cheap *** ebay master cylinder and the clutch pedal never feels like it engages the same twice in a row. i dont think there is any preload but the master cylinder rod is just barely screwed into the pedal.
Old Jan 3, 2008 | 08:37 PM
I bought a 4 big washers with a small enough hole for the bolt to fit through, then I bought 2 big nuts that decently big then bought two nuts that fits inside of the big nut and a hole big enough for the bolt to fit through.
SOrry I don't really have a picture, but if I come across on taking a picture I will
Old Jan 3, 2008 | 08:44 PM
Kevlo911's Avatar
Kevlo for President
I bought these plumbing nuts from Lowes. You just need something that is 3/4 of an inch.
Old Jan 4, 2008 | 06:18 AM
97SMG's Avatar
My rod is barely screwed on too. I forget where I saw actual spacers, I think it was True Value or some other Hardware store that might work well. I also used a few washers, but didn't use enough. My engaging point is pretty high so just as Kev said make sure you use something thats 3/4 thick.
Old Jan 5, 2008 | 07:13 AM
maxima223's Avatar
98maxedout
2 really nice maxs good luck
Old Jan 5, 2008 | 07:23 AM
chillin014's Avatar
so 3/4's on the clutch pedal and no spacers on the master cylinder. i'll have to go re check
Old Jan 5, 2008 | 08:13 AM
nismos14's Avatar
§è~® f®ÈÄk
Kevlo when did you go 5spd?
Old Jan 5, 2008 | 12:34 PM
Kevlo911's Avatar
Kevlo for President
AUG or so.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
JonBlz
Oct 5, 2015 06:02 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
