Front Grille
Old Oct 26, 2001 | 05:33 AM
maxperformance's Avatar
Front Grille
I was curious to where i could find a whole new grille for my 95 MAXIMA. Ive seen pictures where many of you have really nice grilles, and there is three different gaps or wholes cut out in the front. I would love to put like a 3 piece grille in there. I think it called a "billet" grille or something but im not sure. Where can i get this set.. . .i love how you guys modified your max's.
maxpeformance
Old Oct 26, 2001 | 05:44 AM
SLICNIC's Avatar
The only grille they make for a 95 or 96 is the stillen SMX grille, you cand get them from stillen or anyone who sells stillen products.
Old Oct 26, 2001 | 05:49 AM
stillen grille
The only grille that still his right now is defferent. is isnt a 3 peice set like you have
Old Oct 27, 2001 | 02:05 PM
patel_anu's Avatar
make it yourself with mesh grille from home depot, its pretty easy
Old Oct 27, 2001 | 02:12 PM
gregulator's Avatar
like this
Old Oct 27, 2001 | 03:24 PM
97GreenMax's Avatar
That is what I would do if I were you.
Old Oct 28, 2001 | 10:28 AM
Originally posted by gregulator
like this
your grille looks great.. .and you got that from home depot that amazing. Well i was wondering arefter you fitted it in or whatever hoe did you get it to stay afterwards? Did you fit it as the exact hole of did you just put a big strip behind it?
Old Oct 28, 2001 | 01:19 PM
KCTYPHOON
or you can make one like mine , this isnt just a mesh layover, i cut out all the honeycomb and made an entire new grille.. take a look
Old Oct 28, 2001 | 02:00 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Old Oct 28, 2001 | 02:06 PM
KCTYPHOON
better pic ..
Old Oct 28, 2001 | 02:37 PM
phatmax95's Avatar
check out the sig pic ...
Old Oct 28, 2001 | 03:03 PM
gregulator's Avatar
it fit perfectly in there, after i got it cut to size, i just used some small wire and wrapped it around the grill and the mesh and twisted it behind the grill... seems to work just fine.
Old Oct 28, 2001 | 04:10 PM
MAXEJA's Avatar
how felible is the mesh you use in the grill?
Old Oct 28, 2001 | 04:11 PM
ok i went to home depot
Originally posted by Craig Mack
i found the grille material. You guys cut this stuff out perfectly wow. this is ganna take some skill. But i have one guestion did you cut it to exact measurement or did youi just put a big peace in there. Also how did you get the two bottom ones on?!
Old Oct 28, 2001 | 04:50 PM
Craig Mack's Avatar
Re: ok i went to home depot
I'm too lazy to keep repeatin' myself. Try searching...
Old Oct 28, 2001 | 06:04 PM
phatmax95's Avatar
yeah just put the mesh up against where you want it, mark it out with a marker, and then cut with some scissors
Old Oct 28, 2001 | 06:06 PM
phatmax95's Avatar
yup thats what i did too, works better than anything else i tried
Old Oct 29, 2001 | 05:47 AM
the bottom two grilles
it looks great in your max but on the bottom two grilles is it in the middle behind the grille or way up in front i just dont know how to place it. place help id really appriciate it
Old Oct 29, 2001 | 10:10 AM
matty's Avatar
I wanna do it soo badly but I have the license plate...I might just do the top one ?? dont know yet or take the license plate off and do it then put it back on ?? dont know
Old Oct 29, 2001 | 04:20 PM
phatmax95's Avatar
Re: the bottom two grilles
i put it up front, there is a small lip and when you pull it tight with the wire it stays on good
Old Oct 29, 2001 | 04:25 PM
phatmax95's Avatar
first you should at least do the top one, i think that the bottom piece will slide behind the liscense plate, if not take it off and then put it back on.. either way you should do it.. and IF you dont like it it is always completely reversible..
Old Oct 29, 2001 | 04:26 PM
Sexima's Avatar
LOOK GUYS!!
my first time searching for a member
wow.. im in the advanced level now
http://forums.maxima.org/showthread....light=poormans
adamgalazka
Feb 5, 2023 08:24 AM
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Feb 3, 2019 08:34 AM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
