Raising car to work on it
Old Jan 5, 2008 | 09:08 PM
tarun900's Avatar
OK, I'm new to all this car DIY stuff, but there are two ways to raise your car to work underneath it (oil change, etc), right?
1)The jack? So that just hooks onto the sides and raises the car like only in one direction right? Kinda tilts it?
2) My stepdad was telling me about getting a ramp...not sure how exactly it works, but I'm guessing you can set the incline and drive the car up it, set to park, engage hand brake, etc.?
Old Jan 5, 2008 | 09:23 PM
huyqvu's Avatar
im not a big fan of those ramps. i usually jack the car up and set it down on jack stands.
Old Jan 5, 2008 | 09:24 PM
JEXTEL's Avatar
i use ramps.. whats so bad about them?
Old Jan 5, 2008 | 09:45 PM
JtzMax's Avatar
Whatchyou say?
i use both ...
ramps for oil, short shifter .... anything that doesn't require pulling a wheel.
jack is good ... not the factory toy jack, but a decent floor jack and jack stands are the best rout IMHO. to answer you ? ... about a jack - tilting the car, depends on how you use the jack, but in most cases, yes. there are different jack points on the car and depending on the job, you use the right one.
Old Jan 5, 2008 | 10:10 PM
99BlackMaxMS's Avatar
Get yourself a good floorjack and jackstands and call it a day. (That is if you have $150-200 to drop on a decent set )
Old Jan 5, 2008 | 10:21 PM
huyqvu's Avatar
a guy on the local board had a set collapse. cant find the link or pic of it now. im sure there are good and bad products out there. i just feel more secure under the car with some sturdy jack stands. plus ramps wont help you if you do work where the wheels have to come off.
Old Jan 5, 2008 | 10:28 PM
MaxGordon7's Avatar
i have ramps but have never used them. Wait once i used them as rear tire blocks on a car without e - brake...
Old Jan 5, 2008 | 11:01 PM
tarun900's Avatar
Couldn't jacks also technically fail? Hmmm...
Old Jan 5, 2008 | 11:08 PM
huyqvu's Avatar
not if you have a real jack. i have a craftsman aluminum jack.
Old Jan 5, 2008 | 11:34 PM
Yes, that's why you ALWAYS have jack stands under the car in case the jack fails.
ANY jack can fail. And what's funny, is that Craftsman have a very high rate of failing the last few years. Craftsman is wasn't it used to be, in the jack department anyway...
Old Jan 5, 2008 | 11:37 PM
VANGtastic97's Avatar
floor jacks...yes. that's why you should always use jack stands before you get under the car.
Old Jan 6, 2008 | 07:03 AM
Snypa's Avatar
jack stands is the safest way to go.
Old Jan 6, 2008 | 08:12 AM
wetzelman1's Avatar
a friend of mines brother died because he had his car on ramps and the car fell on him and crushed him. I'm not saying it was the ramps fault, but I'm never going to use them, ever.
Old Jan 6, 2008 | 08:15 AM
huyqvu's Avatar
not saying craftman jacks are the best, but mine out lasted my friend's blue point. i wouldnt mind taking his blue point jack stands though
Old Jan 6, 2008 | 01:23 PM
tarun900's Avatar
I'm sure people have also died from jacks right? Or are jacks technically more safe than ramps? A friend of mine's dad uses ramps for oil changes and such and hasn't found a problem with it as of yet.
Old Jan 6, 2008 | 01:26 PM
Fr33way™'s Avatar
Wild for Width
Point is:
1.) Flat surface
2.) Jackstands
Old Jan 6, 2008 | 01:55 PM
pmohr's Avatar
No more Maximas...
Originally Posted by Fr33way™
Point is:
1.) Flat surface
2.) Jackstands
/thread.
Anything can fail, ramps, stands, floor jacks, hell the pinch weld or frame rails on your car can, then you're fscked regardless.
Get some nice stands and you're good.
I'm not a fan of ramps...bad experience with a Dakota and overshooting the ramps (right into the max). In retrospect, very bad idea parking in front of a 2 ton truck when putting it on ramps.
Old Jan 6, 2008 | 02:54 PM
EPcivic's Avatar
You should aways make sure to push on the car after you put it on jack stands to make sure it's secure before climing under it.
Old Jan 6, 2008 | 02:58 PM
mastere954's Avatar
i love using jack and jackstands. i use them like once or twice a week on many different cars and im still alive
Old Jan 6, 2008 | 03:31 PM
sparky1562's Avatar
A good floor Jack, a Pair of jack stands, and Wheel blocks for the other side, if only jack one side up!
My Craftsmen floor jack was probably the first tool I bought, when I was 16, and is still going strong, some 26 years latter!
Old Jan 6, 2008 | 10:02 PM
vajguy's Avatar
I have never used ramps only jack stands.
Old Jan 6, 2008 | 11:57 PM
96i30azn's Avatar
Jacks always seem to bent my car but after what u guys say about ramps...
Lakersallday24
Jun 16, 2019 01:35 AM
ah2002
Mar 9, 2016 01:42 PM
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
