Engine misfire - '98 Maxima
Old Jan 6, 2008 | 03:30 PM
chopperman69's Avatar
My '98 Maxima started missing really bad the other night and threw a check engine light. When I put the code reader on it, it said number 5 was misfiring. I suspected a bad coil, so I replaced what I thought was the number 5 coil. Rear bank, farthest to the right. The misfire is still there.
Any ideas?
Old Jan 6, 2008 | 03:32 PM
mastere954's Avatar
Any ideas?
try the new coil in different spots
Old Jan 6, 2008 | 05:24 PM
The code is P0305 and the misfire is intermittent.
Old Jan 6, 2008 | 05:50 PM
pmohr's Avatar
No more Maximas...
Misfire isn't necessarily the coil (though it most likely is). Could be plug, injector, or wiring for injector or coil.
You were right for cylinder 5, it's firewall side, far left (next to the TB). Did you get a new coil or used?
Old Jan 6, 2008 | 06:32 PM
new coil from Autozone.
Old Jan 7, 2008 | 06:58 PM
I changed the plugs tonight and it appears all is well. Probably should have started there...
Old Jan 7, 2008 | 07:04 PM
96blkonblkse's Avatar
Yeah i did the EXACT same thing. Ihad a missfire in cylinder 5, naturally i swap coils wihtout checking my plugs. Swapped coils and its still there, checked the plugs and they were bad.
Its just a general missfire code, so as pmohr said it could be plug, coil, injector, or even something internal
Hawkeye61
Aug 12, 2015 06:45 PM
Balkins
Aug 12, 2015 06:39 AM
laparka66
Aug 6, 2015 09:36 AM
yat70458
Aug 3, 2015 01:16 PM
