Help: Broke exhaust manifold to Ypipe stud. Clamp-A-Stud?
Old Jan 7, 2008 | 01:40 PM
PhillyDonut's Avatar
When attempting to unbolt the stock Y-pipe off the exhaust manifold, one of the studs broke
Aside from having to do a helio coil treatment, has anyone in this situation tired this ‘Clamp-A-Stud’? Does it work for the Max or any other suggestions?
Thanks!
Old Jan 7, 2008 | 01:52 PM
pmohr's Avatar
No more Maximas...
What is it, a c-clamp that just stays in place?
Drill out the stud, replace with either a new stud or a nut and bolt. Why do you want to take the half-assed approach?
Old Jan 7, 2008 | 02:03 PM
Unfortunately the stud broke off kind of flush (but not exactly, protrudes a little and uneven face) to the manifold making it very hard to drill out; did take a few attempts at that. Also, the location is very hard to reach without taking it to a shop to work on a lift and having to disassemble everything, which I am looking to avoid $$. The two other bolts are good keeping everything in order but there’s just a small exhaust leak and this seems like a good temporary/fixed solution.
Old Jan 8, 2008 | 09:26 AM
Bump, anyone else lucky enough to brake off an exhaust manifold stud?
Old Jan 8, 2008 | 06:37 PM
njmaxseltd's Avatar
I did, 2 of them..
Takes only a few minutes with the car up on a lift to drill them out and replace with a nut and bolt setup.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
Justin Kroll
Oct 1, 2015 07:03 PM
Socalstillen
Sep 26, 2015 12:01 PM
