Passenger window wont roll up?
Jan 7, 2008 | 02:58 PM
Sometime in the last two weeks of automotive chaos, my front passenger window stopped rolling up. Ive checked the stickys and tried a free search(which SUCKS now, btw) but got nothing. There are no fuses, or relays per window, its for the whole power window system. My other windows work fine. Any ideas?
I really just need it up, dont need it to go back down. Ive got class tomorrow...
Jan 7, 2008 | 04:18 PM
Alright, anyone got any ideas? I really am desperate, cant park my car in a garage tomorrow if I dont have windows...
Could I connect the motor to the battery? maybe a bad switch?
Jan 7, 2008 | 06:45 PM
the window will not go up using the passanger door switch nor the main driver master switch?
when you pull/push on the switch ( passenger ), do your light dim?
possible just a loose connection wire that relays to the window's motor/switch?
Jan 7, 2008 | 06:55 PM
as asked, it doesn't work with your d/s switch or the p/s switch? you said you had recent auto problems did by chance you have anything apart?
Also, when you try to lock the car, does it actually lock? It's possible that somehow the wiring to the switch got messed up, which would cause this problem, its also possible that the switch is messed up, but in order to determine either we need to know if the locks work on that door.
Jan 7, 2008 | 07:28 PM
Got it fixed. One of the wires was loose in the connector I guess...when i pushed them in, it worked...for how long, we will see.
