Any tricks to remove timing chain cover?
before peeps flame, my brother and i did search, and all that came up were to remove the covers for the chain tensioner and water pump.
My dad was replacing the water pump on his 95 SE. Got both tensioner and water pump covers off. While working on the tensioner, he dropped a part inside the cover.
So now we are removing the timing chain cover. We got all the bolts off, and have pried the top part of the cover, but the bottom is a pita to pry off.
My dad is currently driving my IS300, so any help to get him back in HIS car is greatly appreciated.
make sure all the screws are out, with a half decent amont of force it should pop off, make sure you didnt miss a screw or you'll just end up cracking the case.
check the side of the timing case, and dont forget there are two bolts in the oil pan that hold the timing case in place. then find angles where you can wedge something in and pry, try many different angles at different spots to get it free. you should feel it giving.
There're some screws behind PS pulley. If you are dropping TC cover, I'd replace chain guide with the tensioner. 95 maximas have old style tensioner and to replace it, you also need to replace chain guide.
Bumping this thread. So far we have not been able to remove the cover, but we have removed everything we can. The clip keeping the alternator on wasn't mentioned in the guide, but it had to be removed to get to the cover (but, it FIRST required removing the bolts from the AC compressor and THEN the Alternator bolts).
This is proving to be a bear of a project JUST to replace the water pump!
The number of additional crap to get that timing chain cover off is just friggin' sick!
Once all the bolts were off, AND the bolts coming up through the oil pan, AND the clip holding the alternator on (which, by extension, meant removing the air conditioner unit), we STILL had to remove a bolt at the power steering assembly from the backside of the engine.
In the process, I broke a plastic timing chain guide (black, upper right side of engine if looking at it through the passenger side quarterpanel) and will need to replace that before getting all this back on.
On the good side, the cover is in good shape and once I take a pick and brush to it, should seal again just fine.
I am looking for the single plastic guide now. All my online searches are thus far proving futile.
All this for a plunger!
site:forums.maxima.org [search phrase]
for example if you want to find stuff about the timing chain cover try:
site:forums.maxima.org timing chain cover
This will return the most relevant threads on the forums.
raffivegas
08-23-2015 09:54 PM
MaximaDrvr
08-19-2015 08:20 PM
Maxima2010 Prem
08-13-2015 11:34 AM
