Window getting sloooooowwwww
My driver's window is taking longer and longer to roll up. (It seems fine going down.) It's starting to make me nervous. Is this likely to be the regulator going out, or is there something I can grease up to make it work better?
usually happens moreso when its cold likely, if thats the case its moreso the resistance of the hardened window seals coupled with a weakening motor, and also as matty said lubing the tracking will help alot as well.
I lube mine all the time especially since I live in the desert area. Remove the door panel. Roll the window up(make sure you plug the power window control back so they work). Spray just in the window channels. Just use some type of spray lube, not wd40. I use motorcycle chain lube cause it stays on better and I had it laying around from my bike days. After you do one window you will do the others cause you will see how much faster it is.
REDinLV
Aug 15, 2024 12:30 AM
