retard timing using knock sensor?
Hey guys,
I was wondering if I could retard my timing by unplugging the knock sensor and having the max use the safe table. The reason I'm asking is because I failed emissions and I need to get them done asap. I failed NOx and I was told that on cars with distributors, they retard the timing to decrease combustion chamber temperatures and reduce NOx levels. Can this be done on the max?
I know its not a fix. I was asking if it could work.
The problem is a restricted egr pipe and I dont have the time to clean it out right now plus its winter and I dont have a garage.
you could try it I do not think it will work cause the car is not under much of a load during testing. I would try 93+ gas, testing the car cold and if you have a afpr add a lb or 2 of fuel psi. high NOx is a result of high combustion chamber temps and a lean burn. since your egr system is clogged try everything else to lower your temps or just slide the guy a few extra bucks
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
yat70458
Aug 3, 2015 01:16 PM
