Bubble in my tire
Re: Bubble in my tire
Originally posted by MacGyver
I nicked the curb and now i have a bubble in on of my front tires. It is just under the tred on the side. Should I just ignore it or am i risking a blow out?
bubbles...
I've gotten bubbles in my tires before..... What you should also do is check the edge or lip of the rim to make sure it isn't bent. I've flew into a hole with my 3rd gen and got a bubble on my tire, well turns out I also bent a control arm and my rim as well. Anyways, bubbles are dangerous, I've driven on them for weeks though and had the car up at high speeds but I strongly advise against this. Last thing you want to do is to blow out a tire while going 70 mph..... The bubble means that the sidewall or where ever the bubble is located has a busted cable inside which means the tire is screwed. You might also get vibration at high speeds... I suggest getting a replacement ASAP.
