Question about Transmission
Old Jan 15, 2008 | 03:50 AM
2blue's Avatar
I have 97 GLE auto...
I usually use my car to tow my quad around and today i put the car in drive and there was nothing there...i would have to rev the car in gear to about 2700rpm and then it would start to creep...what would be the problem?
Once im moving 10-15 mph fast the car drives okay accept alittle rough shifting...any clue on costs of repairs? what could be wrong?
Thanks in advance.
Old Jan 15, 2008 | 05:35 AM
njmaxseltd's Avatar
Have you checked the fluid level lately?
If thats OK, then you need to have your tranny rebuilt. ~2500 bucks...
Old Jan 15, 2008 | 05:58 AM
91parkave's Avatar
same exact thing that happened to mine............it eventually died, look at the thread below "automatic Tranny internal view". However before going to that extreme, make sure your TPS is proper order and that the fluid level is where its supposed to be
Old Jan 15, 2008 | 09:41 AM
dgeesaman's Avatar
Maintenance Monster
Thanks in advance.
Sounds like you toasted it. The cheapest thing is to buy another tranny with low miles and swap it in. Rebuilds are a waste for most auto trannys.
What does your quad and trailer weigh together?
Old Jan 15, 2008 | 09:49 AM
Double E's Avatar
Good question about the weight. I also wonder about the terrian it's having to tow over ...and if Overdrive was ever turned OFF while towing.
Old Jan 15, 2008 | 10:45 AM
pmohr's Avatar
No more Maximas...
Probably no trans cooler either...
Old Jan 15, 2008 | 11:31 AM
2blue's Avatar
Umm The quad and trailer are about 1000lbs..The car ran fine coming home then the next day this happened when the trailer& quad wasn't on the car. I just checked the fluid and thats fine and perfectly red. I drove the car around and just now and sometimes coming to a stop the car wont downshift to first it will start off in 2nd gear..I thought i would just have to replace the tq converter not rebuild the whole tranny.
Old Jan 15, 2008 | 02:44 PM
dgeesaman's Avatar
Maintenance Monster
I don't know too much about autos, but a rebuild of any kind adds up real fast and used auto trannys are cheap and plentiful.
Dave
Old Jan 15, 2008 | 04:47 PM
heynow's Avatar
The staring off in 2nd gear unless completely stopped is an issues for most 4th gen autos, it's the ECU programming.
Old Jan 16, 2008 | 02:23 PM
2blue's Avatar
Today i took a ride and the car acted fine so im really lost..if the ecu has issues do i just reprogram it or reset it?
Old Jan 16, 2008 | 02:28 PM
pmohr's Avatar
No more Maximas...
ECU or TCM?
Old Jan 17, 2008 | 07:12 PM
2blue's Avatar
Huh?
Old Jan 17, 2008 | 07:13 PM
2blue's Avatar
car shudders coming to a stop
Old Jan 17, 2008 | 07:40 PM
pmohr's Avatar
No more Maximas...
...okay?
Why do you think it's an ECU problem? TCM controls the trans almost (if not) entirely.
Old Jan 20, 2008 | 12:52 AM
2blue's Avatar
I didn't think it was an ecu issue i thought thats what you were saying lol.
Tcm controller huh...where is this located?
Old Jan 20, 2008 | 07:17 AM
2da mizzax's Avatar
under the radio. sliver box beneath the black Body Control Module. Have a 97 TCM for sale if you need it.
Old Jan 22, 2008 | 10:22 PM
2blue's Avatar
Thanks i reset it today and did NOT fix the problem
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
I<3 A32's
Sep 10, 2015 11:07 AM
videomano
Sep 8, 2015 03:28 PM
