Cleaning engine...how to cover up wires?
Old Nov 2, 2000 | 07:48 PM
Cumalot's Avatar
People have suggested using Simple Green to clean the engine. About covering up the exposed wires, how do I do it? What about some wires that cannot be reached? And what about the alternator, do I need to cover up that as well? I wish there is a more simple way to clean the engine.
Old Nov 2, 2000 | 07:49 PM
Cumalot's Avatar
Btw, what do I use to cover the wires up with? Masking tape? What?
Old Nov 2, 2000 | 08:13 PM
emax02's Avatar
Engine Cleaning
I just put a empty honey nut chereo bag over my intake and then just hosed down the area and then applied simple green and then hosed it off.Then I took the bag off the Intake and ran my car for 10 minutes to make sure every thing dried off.
Old Nov 2, 2000 | 08:25 PM
Wizeguy's Avatar
I'd suggest the same way you protect your keyboard.
buddumpa...
Old Nov 3, 2000 | 09:51 AM
Cumalot's Avatar
So, it's not necessary to cover up the wires? I rather just spray Simple Green all over the engine bay, and then hose it down.
Old Nov 3, 2000 | 10:18 AM
ny96max's Avatar
if i was you i would never spray down the engine with a hose or power washer. I will send you a pic of what my engine looks like and tell me what you think! All i used was some palmolive and a srubby spong for the majority of the engine, then use MOTHERS aluminum polish and polished the $hit out of the engine. then i wet-sanded the head to make it look like a mirror. 3 steps 400grit,600 grit,1500grit, then re apply some more polish to finish it up. that will give you a sshow quality look!!
Old Nov 3, 2000 | 10:39 AM
jman965765's Avatar
When I did mine, I covered the intake, battery, and the little ecu box thingies.
Old Nov 3, 2000 | 02:47 PM
got rice?'s Avatar
No, cover them up if you spray directly onto the engine. I prefer spraying onto the rag/towel first, then wiping whatever you're cleaning. SG leaves a slight residue if you use too much... follow up with water on a rag on the engine/wires/hoses.
Old Nov 3, 2000 | 04:24 PM
Cumalot's Avatar
Hm...I think spraying SG onto a towel is a better idea. That way I don't need to cover up all the wires; too much hassle. If I use towel with SG, should I finish the whole engine compartment first, then use a wetted towel to wipe of the residue of the SG? Or do one section, then use a wetted towel to wipe of the residue? Thanks.
Old Nov 3, 2000 | 05:00 PM
SmoothMax's Avatar
OG
If you don't mind, why don't you go ahead and send me a pic also.
Old Nov 4, 2000 | 06:01 AM
got rice?'s Avatar
I always do the whole engine compartment first w/ SG-on-the-towel method, then follow up with a slightly damp rag to wipe off any residue. Remember to clean it periodically!! It only takes 5-10 minutes every other week to keep your engine clean. The first time takes the longest..
your engine might look like this someday:
<img src="http://www.cyberhosts.net/~gotrice/ecza/oct21_00/09.jpg">
hehe
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
cruce91
Sep 20, 2015 10:23 AM
boomerbrian
Sep 2, 2015 03:46 PM
