Brake question
Old Jan 21, 2008 | 08:40 PM
maxim82's Avatar
Brake question
my brakes are beggining to sqeak. i checked them this weekend and they do need replacing but i noticed that the inside brake pads are more worn than the outer ones. why does this happen? another thing that i noticed was that the shims were all messed up the one pushing the inner pad and the ones that the pads rest on. do they sell those seperately at the dealer or as a set?
Old Jan 21, 2008 | 08:54 PM
JSMax's Avatar
Sold
usually you get new shims with new brake pads. Sometimes though the pad has an intergral shim that is "bonded" to the new pad.
I would assume that the inner pad is dragging on the disc and that is why the inner is more worn that the outer pads.
Make sure you inspect and lube the sliders on your calipers when doing a brake job.
Use lots of brake clean to clean off the surfaces. Get you disc either new or cut. Oh, and don't forget to bleed your old fluid out.
hope that helps.
Old Jan 21, 2008 | 09:22 PM
TunerMaxima3000's Avatar
as JSMax said, make sure the caliper pins are free, if that caliper is not fully returning to relaxed position your inner pads will wear more.
also check for uneven wear on the pads, which would indicate just one pin holding up.
And have you had the wheel ends off at all? If the wheel ends are not properly torqued they can loose the endplay which helps the calipers release fully
Old Jan 21, 2008 | 09:39 PM
maxim82's Avatar
can i get these shims at the dealer? are they just called brake shims and what kind of grease do you use for the caliper pins or sliders?
Old Jan 21, 2008 | 09:59 PM
pmohr's Avatar
No more Maximas...
Wheel ends?
Old Jan 21, 2008 | 10:06 PM
maxim82's Avatar
^^^^ i was thinking the same thing. by the way, how much do the slighter pins have to be tightened to?
Old Jan 21, 2008 | 10:18 PM
Originally Posted by pmohr
Wheel ends?
wheel bearings/hub/knuckle is what Im talking about.
And the torque on the slider pins is not all that important, but the pins themselves being smooth and properly lubed with a proper caliper/brake lube (sil-glide, etc.) is extremely important, the boots need to be in good condition as well.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
Johnny9595
Sep 3, 2015 05:18 AM
