Low fuel light ever come on for you?
Old Jan 25, 2008 | 04:39 PM
  #41
Roadkill's Avatar
i was a little below E today and no light
Old Jan 25, 2008 | 04:43 PM
  #42
Nealoc187's Avatar
SLOW
mine was on for longer than I like it to be, about 20 minutes yesterday, and i fulled it up with only 16.5 gallons.
Old Jan 26, 2008 | 07:26 PM
  #43
90EightSE's Avatar
I was only able to get mine to illuminate after driving on "E" for more than I like to but I had to check. It took, I figure, around 20+ more miles of mild city driving. I didn't enjoy testing the lamp btw.
Old Jan 27, 2008 | 09:30 PM
  #44
TunerMaxima3000's Avatar
Originally Posted by dgeesaman
The fuel pump is always sucking fuel from the very bottom of the tank.
This idea of staying away from the low tank levels is basically a myth. Run as low as you want, about the worst you can do is get fuel starve and engine knock, or maybe you'll burn up the fuel pump if it runs dead dry for while. But there is no gunk involved.
Usually you'll get fuel starve while cornering hard or starting from a stop long before you empty the tank to the point of damaging the fuel pump.
Dave
Old Jan 27, 2008 | 09:39 PM
  #45
MrDicks95SE's Avatar
Offset Is Everything.
Originally Posted by ROCKART
im just going to have to ask you to go ahead and gtfo
ask me to gtfo? : you need to look at your own posts and threads and think about what you said.
Old Jan 27, 2008 | 10:45 PM
  #46
JOMAN's Avatar
i thought the 4th gens only had a 16gallon tank?...
i usually fill up close to 16... this is interesting info...
good thread.
Old Jan 27, 2008 | 10:51 PM
  #47
good thread.
4th gens have an 18.5 gallon tank.
Old Jan 27, 2008 | 11:53 PM
  #48
Qbridg3's Avatar
Mine comes on. The bulb shouldn't burn out anyway since it's the same type of bulb for the CEL, seatbelt and those come on and off more often than the low fuel light and they don't burn out.
Old Jan 28, 2008 | 07:30 AM
  #49
Lumberg™'s Avatar
on this site too damn much
mine comes on all the time, that's when i know to put 20 more bucks in
Old Jan 28, 2008 | 08:56 AM
  #50
udienow's Avatar
My light comes on all the time. It doesnt however stay on till im below the E marker. The guage goes a bit below E for me. However even after driving for 20+ miles below E I have yet to be able to fill up more then 16.5 gallons. Apperently after below E i still have 1-2 gallons left in her. But I get worried driving on below E with the light on, so I never push it. Yet to run out of gas, and planning to keep it that way. The light starts to go on and off (mainly on turns) once im below 1/8th tank left, but doesnt stay on till well below E... and even then it turns off and on once in a while. But yeah the low fuel light def works, so if it isnt turning on / off... somethings not working.
Old Jan 28, 2008 | 09:47 AM
  #51
adamsanders's Avatar
I have yet to see mine at all. I have driven several times to until the end of the needle is about a mm away from the E and have not seen it. When I fill up at that point though I can only get ~13.5 gallons in her. I guess I should't worry about running out when I get that low anymore, seeing as I should have like 4 gallons left.
Old Jan 28, 2008 | 09:48 AM
  #52
wuzzy's Avatar
I have a 95 and never seen it go on. I usually fill 14.5 gallons
Old Jan 28, 2008 | 10:35 AM
  #53
Lumberg™'s Avatar
yeah the light won't go on until you can see a gap between the E line and the needle and the needle is below the line.... i think most of you think it comes on when it hits the line
Old Jan 28, 2008 | 07:46 PM
  #54
DragonMaxima's Avatar
95gxe never seen it come on. Filled up past 16 gallons a few times.
Old Jan 29, 2008 | 03:26 PM
  #55
JOMAN's Avatar
WOWzerss....my tank goes empty on 15 gallons my needle is point at E...hmmm anything i need to get my gas tank replaced is its that off? now i know i get reach 400 miles and more instead of gasing around 360....
Old Jan 29, 2008 | 06:20 PM
  #56
the rest is the reserve tank.
Old Jan 29, 2008 | 06:53 PM
  #57
icaghost's Avatar
as exemplified by a classic Seinfeld episode, the needle, can, indeed, go below the E line
Old Jan 29, 2008 | 10:10 PM
  #58
johnnyboy's Avatar
Gunk at bottom of tank
Its impossible to have gunk cause when you pull up for a refill it take jsut about two to three minutes to fill up to a good 16 gals .16 gals in3 minutes so imagine the force at with gas is poured in... really fast to give a good cleaning to ur tank so if any gunk gets there by any chance it is surely stired up during refill and ends up in the filter so no worry if ur low on fuel about getting gunk in ur system its never there
Old Jan 29, 2008 | 10:25 PM
  #59
MaximaSpd85's Avatar
boy arent we glad we dont know exactly how much fuel is in the tank when the light comes on.....otherwise we'd have a lot of people keeping track and running the tank down to the last drop, haha
Old Jan 30, 2008 | 07:17 AM
  #60
shotty's Avatar
Do you have white faced gauges by any chance? On my SE the light is so faint through the white face(There's no clear spot for the light) that it's almost impossible to tell if it's on.
Old Jan 30, 2008 | 10:40 AM
  #61
Lumberg™'s Avatar
^^ I'm guessing you mean aftermarket.... I think most of you don't realize that the needle has to be BELOW the E line for the light to come on. I have to see a gap between the needle and the line before it comes on. I'm sure most of your guys light is working fine, you just never bring it down that low
Old Jan 30, 2008 | 10:43 AM
  #62
ROCKART's Avatar
wants an I35
naw mine turns on while the needle is above the E line. probably at like 1/6th of the full range.
Old Jan 30, 2008 | 12:16 PM
  #63
Lumberg™'s Avatar
weird... mine never turns on till well below the e line and when i fill my tank my needle goes to just about the top of the F line
Old Jan 30, 2008 | 10:52 PM
  #64
MaximaDvr's Avatar
Im one of those people who only likes to fill up half a tank at a time, so what i've started doing is fill up all the way then when i get down to half a tank i fill up again. Better to have too much fuel than too little."
My father does this as well. I however, have found that I get better gas mileage if I wait until I'm right around E so I go till the light turns on.
On my SE in the day time, it was pretty much impossible for me to see the gas light on.
Old Jan 31, 2008 | 10:35 AM
  #65
Crusher103's Avatar
I wait till Im close to E then I fill up, I found that it is good to let it run down to almost empty then fill it up again, I got around 370 miles on one tank going to the mountains once 65-70 mph on cruise control lol it was $50 to fill it back up at $3 a gallon
Old Jan 31, 2008 | 10:40 AM
  #66
ROCKART's Avatar
wants an I35
if i push it on highway mileage i can get 460-470 mpt.
Old Feb 5, 2008 | 02:59 AM
  #67
flynlr's Avatar
i see the light I know its time to put another 16.5 gallons in the tank. been doing that since 95 when I bought my max
Old Feb 14, 2008 | 03:18 PM
  #68
diamondtcb's Avatar
Mine comes on around 1/8th of a tank.
Old Feb 14, 2008 | 03:23 PM
  #69
LeVeL's Avatar
Came on the other day but I didnt get a full tank so not sure how empty it actually was. The needle was DOWN though
Old Feb 18, 2008 | 08:48 AM
  #70
Roshansri's Avatar
Okay guys, were going off topic here, we are all stating that the needle has to be below E and between what ever to see the light, well here is news !!!!. I drove mine till it stopped in the middle of the road. AND STILL NO LIGHT CAME ON!!!! had to walk my sorry butt to the gas station to get some gas and then refill it again. SO WHATS THE PROBLEM.?? anyone here got this looked into? has anyone taken it to a dealer or a mechanic who said if its the light problem or the a sensor????
Old Feb 18, 2008 | 10:09 AM
  #71
WaltL's Avatar
Mine light never comes on either. I was trying to see how many miles I could eek out of a tank before it came on... but ran out of gas at ~ 424 mi on the tank. Luckily, I was able to coast downhill into the gas station
Guess I need to check the low fuel bulb!
Old Feb 18, 2008 | 12:40 PM
  #72
sparky1562's Avatar
Mine never comes on. Of course I fill up at 1/4 tank so I don't run out of case in the middle of nowhere! Why don't you guys try that?
Old Feb 18, 2008 | 01:26 PM
  #73
lil_Jay22's Avatar
This too happened to me a while back with no light coming on so I don't even let it go under a quarter anymore.
This seems to be a common issue, hopefully we can pin point the problem.
Old Feb 18, 2008 | 03:26 PM
  #74
AllMaxxedOut's Avatar
Only happened one time where I let the tank go by E. Of course I've never did that again.
Old Feb 18, 2008 | 10:31 PM
  #75
99 se maxx's Avatar
yea dudeee mine never comes on eatherr dunno whyyy.....
Old Feb 18, 2008 | 11:41 PM
  #76
aapp81's Avatar
I've owned the car for about 70k miles and have never seen the light (don't know about previous owner) - and I've run out of gas once.
I've had the ORIGINAL cluster out to do work w/ gauge lights and replaced the bulb but that didn't help.
I than bought an SE cluster from eBay and the light never worked in that one either.
My conclusion? There must be a sensor that's busted in the tank or somewhere before the cluster...
Old Feb 19, 2008 | 10:33 AM
  #77
tk1971's Avatar
Only when running on fumes.
tk
Old Feb 21, 2008 | 04:28 AM
  #78
20V6's Avatar
I've been told by the dealership that there is a separate switch for the low fuel light on the fuel pump / fuel sending unit. They say it's fastened with cable ties and has been known to slide down from it's original position. Then the light doesn't come on anymore.
Can't verify this, haven't looked at it myself.
Old Feb 21, 2008 | 12:00 PM
  #79
GLE96's Avatar
mine hasn't come on, my needle was on E and the light wasn't on...
Old Feb 21, 2008 | 05:42 PM
  #80
JtzMax's Avatar
Whatchyou say?
Originally Posted by 2da mizzax
98+ have a reserve tank (IIR), which may be why yours didnt come on. I saw run it dry to be sure. Mine comes on all of the time. I have about 20 more miles in me before I run out of gas (yes I have done it before).
Reserve fuel ???? What ... I like it. Didn't know that, but I am glad Nissan did it for those of us who like to use 17 + Gal befoer filling up. lol Mine comes on just as the pin hits the red line.
