glowing needles package question
I ordered the glowing needle thing last time
it arrived and i was so happy.
I look in the box and all i see is some wiring..
no needles?
soemthing wrong or is this normal
no needles?
blue lighted needles
so let me get this right here.there are blue needles you cn buy.then there is also a kit available to make your stock se needles blue,but you have to sand off the orange in the back of the needles.is this correct?
Originally posted by Nick Robinson
Yep thats all you get. Looks kinda cheap doesnt it? They work though, but be carful you dont mess, and have your gauges sticklike mine
These are not that bad to install, just read the directions several times to make sure you know what you're doing and be very slow and methodical.
The only tip I can give is to take a drill bit and enlarge the hole in the gauge face that the needle shaft goes through. Make it just big enough that the rings fit flush with the gauge face and you should have no problems.
I've had mine since they started offering them and they don't stick at all.
i think if feel your mechanical skills are good, then you should attempt this project on your own. if not, you run the risk of damaging your gauge cluster. do a search on indiglo needles and read other posts that have been written on this subject. it may give you additional background to help you make a better decision on whether to try the install yourself.
if you screw up, a new gauge cluster is fairly expensive--several hunderd if purchased at the dealer, a used one is about $110. it is good to learn by trying new things, but be prepared to live with the consequences.
zzznightmarezz
Sep 21, 2015 06:32 PM
pears
Sep 18, 2015 05:25 AM
sdotcarter
Sep 2, 2015 09:53 PM
