r34 Lens
Old Jan 31, 2008 | 02:33 PM
AndrewR2442's Avatar
r34 Lens
So i have r34's. And I must get really stupid at 2 AM.
I pulled my lens off and started sanding w/only 2000 grit attatched to a rubber flat sanding block to get bugs and slight interstate pitting off. I wet sanded this for about 2-3 minutes (w/only 2000). It was hazy and now it's still hazy after trying to polish w/Meguire's PlastiX.
I guess i'll try wet 600, wet1000, wet2000, polish w/3M rubbing compound then Meguire's PlastiX
90 degree angles right? What motion? Up, Up, Up, Left, Left, Left, or,
Up and Down then Left and Right (back and forth) ????
How long should i sand w/each grit? 5 min's each grit or like 15 or more? ????
I couldn't find the definitive answers
BTW Thanks to any comments
Old Jan 31, 2008 | 02:43 PM
MOHFpro90's Avatar
No need to go down to 600 unless there is a lot of discoloration or damage, scratches etc...
Did you hand buff? Try an orbital/random orbital with a foam/microfiber pad.
Pattern? I just sand...I never see a difference.
IMO, Stick with > 1000grit, anything lower can cause deep scratching. If you want to go through all of them, you sand until the scratches from the lower grit disappear and it becomes smoother. Probably 3-4min each.
Old Jan 31, 2008 | 05:06 PM
Flava_24/7's Avatar
Boosted Panda
You wont get a nice glass like appearance from hand buffing.
Old Jan 31, 2008 | 07:50 PM
JSMax's Avatar
Sold
Start with WET 1500 grit. Keep it moist and go in back and forth motion.
After a few minutes, switch up to 2000 grit WET and use in the opposite direction.
Again, probably 3-4 minutes, move on up to 2500 WET and go back and forth.
It dosen't really matter which direction you start with as long as you change direction when you change sandpaper.
Make sure the paper is WET by letting it soak in water for apx. 10 minutes.
Use your orbital to apply polishing compound.
You will have to finish with plastic-x or whatever.
Hope that helps.
do this when sober your results will improve dramatically.
Old Feb 1, 2008 | 02:38 PM
A99MAXIMA's Avatar
Just get a mothers powerball, it fits in your drill. It worked good for me after wet-sanding w/ 600 grit
Old Feb 2, 2008 | 10:20 AM
maximabebe's Avatar
No.
Break the wrist, then walk away.
Old Feb 2, 2008 | 07:33 PM
I can't get it to clear and shine like water!!!
Is 3M the best rubbing compound? and PlastiX the best water clear polish?
Old Feb 2, 2008 | 07:41 PM
MaXiM@KiD's Avatar
MaXXiN
I just wanna say you car lookss sick bro!!!
Old Feb 2, 2008 | 08:46 PM
MOHFpro90's Avatar
Old Feb 5, 2008 | 07:59 AM
nemesys's Avatar
Flava_24/7 those are the best lights I have ever seen on a max. where the hell did you get that done, or how did you do it?
Old Feb 5, 2008 | 09:09 AM
Flava_24/7's Avatar
Boosted Panda
I created them myself.
http://forums.maxima.org/showthread....dual+projector
Old Feb 8, 2008 | 02:12 PM
nemesys's Avatar
the link won't work
Old Feb 8, 2008 | 04:51 PM
XAugusta MoonX's Avatar
Hahaha see the smiley between the "sh" and "ow". Yeaaaahhhh
Old Feb 8, 2008 | 06:26 PM
Flava_24/7's Avatar
Boosted Panda
the link won't work
Try it now...
Old Feb 8, 2008 | 06:28 PM
Flava_24/7's Avatar
Boosted Panda
Thanks!
Old Feb 9, 2008 | 11:18 AM
nemesys's Avatar
flava 24_7 thanks for the link. I think I'm gonna try some bmw projectors to get the halos
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
kjlouis
Sep 14, 2015 11:22 AM
