Heater Issues
Old Feb 3, 2008 | 02:15 PM
J_Swaleh's Avatar
Heater Issues
My heater is acting retarded. When the car is completely warmed up and I turn on the heater, it will heat up for a good 30 sec. and then blow cool air. It keeps heating up and cooling down as I drive down the road. What could possibly cause this?
Old Feb 3, 2008 | 02:17 PM
NmexMAX's Avatar
dot dot dot ...
How's your thermostat?
Old Feb 3, 2008 | 04:15 PM
da God's Avatar
wtf?! thats bugged out.
Old Feb 3, 2008 | 06:31 PM
J_Swaleh's Avatar
I dont know, is the thermostat relative to what temp the air is on the heater?
Old Feb 3, 2008 | 06:33 PM
NmexMAX's Avatar
dot dot dot ...
It's probably stuck open.
Old Feb 20, 2008 | 02:23 PM
apollyon's Avatar
min's doing the smae thing if i rev it, the heater blows hot air if i idle its cold... help!!
Old Feb 20, 2008 | 02:53 PM
2da mizzax's Avatar
if your thermostat is stuck open, you will see the temp drop as you drive faster down the street/highway and go back up when not moving. What you are describing (both of you) sounds like a clogged/partially clogged heater core that only allows circulation when the water pump spins faster and puts more pressure on the system. Sounds like time for a serious system flush.
Old Feb 20, 2008 | 03:03 PM
DCZC's Avatar
Another thing to check is coolant level in the radiator, if the system is low it can cause erratic heating. i personally experienced this on a vehicle I used to own. no guarantees, but that was my prob and definitely worth a check, check the radiatoras well, not just the dummy tank. If not, I second the motion to have the system flushed, clogged heater cores suck!
Old Feb 22, 2008 | 09:25 AM
HarryZonker's Avatar
Low coolant level is a big reason for this behaviour (cold air from heater @ idle)
Old Feb 22, 2008 | 09:53 AM
KRRZ350's Avatar
Low coolant level
Bad thermostat
Plugged heater core
Malfunctioning vent control
Those are just a few that came to mind, there is a very good preliminary checklist flow-chart thingy for diagnosing insufficient heating in the FSM
Old Feb 23, 2008 | 04:09 PM
Fasteddie01's Avatar
Is tis for real - - yu'v been mbr for 2 years and don't know how this works. Sorry for the flame - but get real
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
RWCreative
Sep 21, 2015 11:01 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
