Failed Smog, please help, drive cycle?
Old Feb 4, 2008 | 09:12 PM
sblax2000's Avatar
I took my car in today for a smog and it failed. I was told that the drive cycle hadn't completed so they couldn't run the test. I have not unplugged the battery in months and just got back from a 10-hour roadtrip, so it seems like the system should have gone through its checks. I did clean the MAF sensor and intake prior to this trip, but it still should have reset by now. I noticed this morning that the air temp sensor had fallen out and I reattached that but am not convinced that would cause and issue.
Does anyone have any ideas?
Thanks.
Old Feb 5, 2008 | 01:04 AM
zachosz's Avatar
If you recently reset your ECU, then it makes sense that the drive cycle hasn't completed yet. I think it takes a couple of weeks of normal driving for the ECU to be ready for inspection. If you didn't reset the ECU then sorry, can't help you...
Old Feb 5, 2008 | 03:14 PM
sblax2000's Avatar
Thank you for your response. I think the check engine light came on 2-3 months ago and I reset it then. Unfortunately, I have driven over 1500 miles since then. Any other ideas?
Old Feb 5, 2008 | 04:52 PM
UncleMax98's Avatar
There are 8 monitors. Do you know which one is not ready? There is a section in the Owner manual to get the car ready for emission testing.
Old Feb 6, 2008 | 11:12 AM
sblax2000's Avatar
I don't know which one is not ready. I wasn't able to find anything in the owner's manual, but did find a small section in the Chilton manual about extracting codes and read through that section. The check engine light has not come on for about 2-3 months. What would you recommend doing?
Thanks.
Old Feb 6, 2008 | 01:16 PM
UncleMax98's Avatar
How to get car ready for emission testing (Owner manual chapter 10-18)
1. Start the engine when the engine coolant
temperature gauge needle points to C. Allow
the engine to idle until the gauge needle
points between the C and H (normal operating
temperature).
2. Accelerate the vehicle to 55 MPH (88
km/h), then quickly release the accelerator
pedal completely and keep it released for at
least 6 seconds.
3. Quickly depress the accelerator pedal for a
moment, then drive the vehicle at a speed
of 53 to 60 MPH (86 to 96 km/h) for at least
5 minutes.
4. Stop the vehicle.
5. Accelerate the vehicle to 35 MPH (55 km/h)
and maintain the speed for 20 seconds.
6. Repeat steps 4 and 5 at least 3 times.
7. Accelerate the vehicle to 55 MPH (88 km/h)
and maintain the speed for at least 3 minutes.
8. Stop the vehicle and turn the engine off.
9. Repeat steps 1 through 8 at least one more
time.
If step 1 through 7 is interrupted, repeat the
preceding step. Any safe driving mode is acceptable
between steps. Do not stop the engine
until step 7 is completed.
captchaos
Mar 15, 2016 12:18 PM
gustavison
Oct 4, 2015 06:50 PM
Maxie40
Sep 14, 2015 11:28 AM
sdotcarter
Sep 2, 2015 09:53 PM
