pic: dirty a$$ evap volume purge control valve...solve CEL 1008?
Old Feb 5, 2008 | 03:34 PM
black_maxed95's Avatar
so im getting CEL 1008 (P1445) which is for this thing so i take it off, do the ohmmeter test (which it fails) then i set it down and little black flecks fall out. upon more shaking i get all this. it smells like gasoline (expected) but why do i have this carbon build up in it?
Old Feb 5, 2008 | 04:24 PM
well the real problem was discovered...the inside electrical connectors are corroded to ****.
still doesnt explain the black crap tho
Old Feb 5, 2008 | 04:44 PM
guess im buying a new one.
Old Feb 5, 2008 | 04:54 PM
vilmaxima's Avatar
I might have aproblem like this also, the small black vacuum tube that runs from the EVAP canister purge control valve to the EVAP canister purge volume control valve(the one u have pictured above), the hose is sucking itself closed when in P or N, and starts making a ticking noise, I gotta take mine apart check it out.
Old Feb 5, 2008 | 04:56 PM
yup, makes sense, the valve in mine was stuck closed and it also made a ticking noise. are you also getting a cel 1008 (P1445)?
Old Feb 5, 2008 | 06:14 PM
sparky1562's Avatar
If the evap valve is bad, could it cause a smell of fuel in the car?
How many miles on that valve?
Old Feb 5, 2008 | 06:17 PM
it shouldnt cause a smell cause it should still be sealed. assuming it was never replaced before i got the car, 170k miles
Old Feb 5, 2008 | 06:39 PM
VANGtastic97's Avatar
Hey I accidently removed that "thing" when I was looking for the IACV...i know. So i decided to take it apart and stripped one of the three bolts. I don't have any codes, but I also have a ticking noise right around that area of the engine bay. What's the specific ohmmeter reading supposed to be around?
Old Feb 5, 2008 | 06:51 PM
30 ohms, there are 6 prongs:
123
456
the 30 ohms is measured between 2 and 1, 2 and 3, 5 and 4, 5 and 6.
Old Feb 6, 2008 | 05:54 AM
Chief Brody's Avatar
Hmm, I remember cleaning out some charcol (I think it is from the canister in the back, not from anything combustion related) when I was trying to chase down the stupid 1444 code.
Old May 14, 2008 | 01:02 PM
julioenr's Avatar
bad canister
Well the carbon build up comes from the EVAP canister, on the back of your car. It means it is internally broken and must be replaced.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
