Vacuum hose from EVAP purge control valve to EVAP purge volume control closes itself
Old Feb 5, 2008 | 05:04 PM
vilmaxima's Avatar
Allright, this has been botherin me for quite some time. As the title states the small black hose from the EVAP purge control valve to the EVAP purge volume control is sucking itself closed only in P or N(automatic) and starts making a ticking noise, I got no CEl's, tommorrow Im gonna take apart the EVAP purge volume control valve see if its clogged. Anyone ever had this issue? What were the causes? Thanks
Old Feb 5, 2008 | 06:38 PM
vilmaxima's Avatar
just took apart EVAP purge volume control valve, looks brand new, could it be the EVAP purge control valve? I dont wanna buy anything if thats not the cause.
Old Feb 5, 2008 | 07:41 PM
MOHFpro90's Avatar
Getting a code for anything? IIRC there is a way to check to see if the canister is working properly.
Old Feb 5, 2008 | 08:16 PM
black_maxed95's Avatar
he says he has no codes. is the hose really flimsy? the hose for my evap stuff is pretty thick and i cant imagine it being suck closed under any normal pressure.
Old Feb 5, 2008 | 08:34 PM
vilmaxima's Avatar
No i got no codes. Good point about the hose, I forgot to add that it is not the stock hose, it is rather flimsy, since I replaced my vacuum hoses with blue ones from Canadian Tire(were meant for vacuum hoses), I cant find my stock hoses, well I guess Ill try a thicker hose. The weird thing is it just started doing this a couple of weeks ago and I have had the blue hoses for almost two years. Thanx for the help.
Old Feb 5, 2008 | 09:08 PM
the engine heat will eventually make cheap hoses flimsy. now im not 100% sure on this but i think the hoses might be fuel hose since after all the evap is for fuel vapor. but ya just get some better hose.
Old Feb 6, 2008 | 05:19 AM
njmaxseltd's Avatar
Get a good quality hose on there, engine vacuum can easily pull a flimsy hose closed.
Blue hoses = RICE
Old Feb 8, 2008 | 11:43 AM
vilmaxima's Avatar
I got a fuel line hose on there, havent checked yet if it still makes the ticking noise. thanks guys
captchaos
Mar 15, 2016 12:18 PM
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 7, 2015 07:26 AM
03VQMAX
Sep 5, 2015 03:47 PM
TheMafia
Sep 4, 2015 08:26 AM
