Rattling noise coming from my front right driveside wheel
Old Feb 5, 2008 | 07:31 PM
Racer_M's Avatar
You know how I do....
Initially I thought it was my axle...I've had 2 people check it out, and tell me my axle is fine and they can't hear the noise I hear. That's the catch, the noise is intermittant, and I hear it mostly when accelerating in turns. Any idea what it could be, the sound is starting to become more persistent.
Old Feb 5, 2008 | 07:39 PM
Fadrvr's Avatar
cv joints.
Old Feb 5, 2008 | 08:46 PM
vilmaxima's Avatar
cv joints, or strut bearings, could be swaybar link also.
Old Feb 5, 2008 | 08:48 PM
cape99max's Avatar
Again
I have recently just replaced both sides.. and had the same symptoms!
CV
Old Feb 8, 2008 | 03:15 PM
SamMan23's Avatar
It could be your wheel bearings.
Old Feb 8, 2008 | 04:33 PM
BeZerK2112's Avatar
This is fun! Strut mounts can make ratteling noises when they come apart. Mine started intermintently and then became more persistant.
Old Feb 10, 2008 | 08:43 PM
96SEmaxB's Avatar
I have the same problem, i hear it randomly, and it almost sounds like it's inside the cab. Gets worse around 50-70mph on mildly bumpy roads... so you think it could be strut mounts? i was told cv, but it's not a 'clicking' noise.. it's a clank.......clank..
Old Feb 10, 2008 | 09:05 PM
MrDicks95SE's Avatar
Offset Is Everything.
take apart you suspension and problem solve. check all bolts and nuts, strut bearings, wheel bearings, etc. also make sure your lugnuts are tightened when youre all finished.
Old Feb 10, 2008 | 10:44 PM
WhiteMaxima9600's Avatar
I had that exact same problem for years until I lowered my car. I believe mine was in the strut. I had both cv's and axles replaced but still the thud thud sound. Look at your suspension for the problem if you don't think it's the axles.
Old Feb 12, 2008 | 10:55 AM
Double E's Avatar
I had recenly changed my axles (used non-oem parts & a private garage) when I started getting the rattle too. I though timing chain tensioner, bad installation, struts, etc and it also went to the dealer twice for a look over. It drove me crazy.
I finally decided to crawl up under it and stay there till I found it ...and I did. A rubber mallet tapping on everything was the key to hearing it while under the car.
On the passenger side drive axle, there was a dust collar on the tranny side of that axle that had come free from its cheap spot welds. This collar was spinning aroud the axle and when I hit bumps at speed, it would wobble around the axle and rattle. A little RTV on the face of it, and all was right with the world again... There may be a similar setup on the driver's side axle. Might be worth a look.
Old Feb 12, 2008 | 06:31 PM
bellardo89's Avatar
mine did that it was the cv joints
Hondarydr
Dec 30, 2024 06:15 PM
kingw323
20
Oct 21, 2015 08:36 AM
follyburr
Aug 7, 2015 09:50 PM
BassAddictJ
Aug 4, 2015 11:38 AM
Jcof88
Aug 3, 2015 10:43 PM
