1500-2000 idle undulations when warm? Vac leak?
Old Feb 6, 2008 | 04:28 PM
MOHFpro90's Avatar
While in P or N, at stop, my idle undulates from 1500-2000 rpms, only when warm. I am thinking vacuum leak, but I cant find it? Is it possible for the metal gasket on the heads to the LIM to go bad? Mine is not rusted, just some of the black paint flaked off. Any ideas?
Old Feb 6, 2008 | 04:58 PM
cardana24's Avatar
Blown
I have a high idle when the temp. gets cold, I don't have any intake leaks to my knowledge and I have still never been able to figure it out. But as far as the LIM gaskets they are crush gaskets so after you use them once the ridge is gone, so yes it is possible to have a leak there if you re used them. have you tried using some carb/choke cleaner to find a possible vac leak?
Old Feb 6, 2008 | 05:12 PM
jblinga's Avatar
Maybe this is your problem...? You might not have got it sealed 100% as you thought like you said in your Macgyver thread.
Old Feb 6, 2008 | 07:20 PM
MOHFpro90's Avatar
As said about 4 times in my thread, I fixed that today. Geeze people read. (no personal offense, it just seems it has been going on a lot lately)
Cardana, how high is yours when cold? On a cold start mine is atleast 1200, then works its way to 1500 then jumps up and down.
Old Feb 7, 2008 | 02:36 PM
cardana24's Avatar
Blown
on start up its fine, around 1200 or so. But when the engine gets up to temp and has been run for (just a guess) more than 15 minutes the idle will creep up to around 1800. My dyno's look fine and my track times (13.8 @100) back up the fact that my car does not have anything major wrong with it, but the high idle is annoying.
Old Feb 7, 2008 | 02:49 PM
LeVeL's Avatar
1500-2000 rpm idle? Jesus, mine idles at ~750! I vote leak, as you guessed.
Old Feb 7, 2008 | 02:50 PM
MOHFpro90's Avatar
I was told by a mechanic friend after I sent him a short video of the idle that yes, it was a leak. Any suggestions on finding it?
Old Feb 7, 2008 | 03:47 PM
Start with spraying some soapy water around the area you just repaired. Then spray around other vacuum areas..
Old Feb 7, 2008 | 04:15 PM
njmaxseltd's Avatar
Spray carb cleaner around the area. When you hit the leak, your idle speed will jump.
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
