Knock sensor question.
Old Feb 6, 2008 | 09:13 PM
Divewjason's Avatar
I'm finally down to the last small problem on my car. It's been a rough road on getting this car to run right but it was worth it.
Now for the final repair I have to make: My car is idling rough. It doesn't idle rough in Park. I haven't tried neutral yet, but if I have my foot on the brake at a stop light my car will shake and I'll see the idle drop down on my rpm gauge for a split second and it will go back up. It will do this repeatidly.
I checked the codes, I'm throwing a knock sensor code. I heard that the knock sensor can mess with the idle so I figured that might be it.
My Dad had other ideas, he wanted to put in this BG-44k stuff into my car, when he did that, the car didn't shake at the stop light. However, once I had to fill up the gas again, it idled as bad as ever.
Is this really my knock sensor or is it something else? Was the BG-44k that stopped the shaking for a bit do something to temporarally help the knock sensor? This really has me puzzled, any input would be appreciated.
Old Feb 7, 2008 | 06:04 AM
oldngivout's Avatar
Willing to learn
Knock sensor has ZERO effect on the engine idle. You need to keep looking.
Old Feb 7, 2008 | 06:19 AM
ROCKART's Avatar
wants an I35
yea KS has nothing to do with idle.
sounds more like an intake/throttle problem
have you cleaned your throttle body and idle air control?
that causes 90% of rough idles, tho i would have to see it to know
also, now seeing you have a 99, it could be coilpacks, but the CEL would show it if it was
id be glad to take a look at it this weekend
pmed you my cell.
Old Feb 7, 2008 | 07:11 AM
Divewjason's Avatar
pmed you my cell.
Thanks. I will check my work schedule today and see if I can do it.
I have not cleaned any of that stuff, I have no idea how. I guess I should check the stickies.
Old Feb 7, 2008 | 07:35 AM
Divewjason's Avatar
By throttle body do you mean the TPS? My car is showing the systems of a faulty TPS. Although it may be just dirty.
Old Feb 7, 2008 | 07:44 AM
ROCKART's Avatar
wants an I35
TPS is throttle position sensor.
that should be ok unless you (or someone else) has messed with it in the past. its a pretty sensitive item.
throttle body is this.
http://forums.maxima.org/showthread....+throttle+body
the pics have been deleted tho cuz i changed my photobucket, so it is
Old Feb 7, 2008 | 07:56 AM
Divewjason's Avatar
Alright, thanks a lot ROCKART.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
