Starting problem. Please help!
Old Feb 16, 2008 | 10:05 AM
ExoticCreations's Avatar
I have a 96 maxima. I have problems starting sometimes. When i crank it, it doesn't start. You hear it trying to, it almost sounds like the timings off. And sometimes it is no problem. It has a brand new starter. And brand new fuel pump. The only code i have is a p1400 for the egr. What could it be? I have a second maxima i could switch sensors or what ever. By the way its 5-speed. I notched when it does it if you hold the key down and just blimp the gas it starts.Could it be TPS?
Old Feb 16, 2008 | 10:19 AM
maximabebe's Avatar
Where did you get your starter from? What kind of symptoms did you have relative to your situation with the previous starter?
Old Feb 16, 2008 | 10:21 AM
I took the starter off the other max i had. to see if the problem was that.
Old Feb 16, 2008 | 11:15 AM
I found out it was the ignition module. I just replaced it with one from napa about 2 months ago. I put a nissan one in and it worked. POS NAPA
Old Feb 17, 2008 | 02:04 PM
GoldMax96's Avatar
I'm going through the same problem with my car right now, the car just wont turn over until i give it gas or if i leave it turned long enough it wil finally go...i've brought it to at least 4 shops and all have told me they cant find a thing wrong with it..I am guessing fuel pump but dont want to take a guess and spend 400 dollars, does anyone know what it could be?
Old Feb 17, 2008 | 02:38 PM
x X CLoud X x's Avatar
Im having the same ****ing Issue, this car is pissing me off more and more, i thought i had fixed it 2yrs ago by Replacing, Battery/Starter, worked fine for about 1yr, and now the dam thing wont crank, not even a clicking noise
Im gonna try Pushing Starting it (since its 5speed) and bring it back to a dam Shop. Once we get this thing to work, im gonna trade this POS in for a used
S4
ps- only thing i can think of to replacing now would be Alternator/Coil Packs/Spark Plugs
Old Feb 17, 2008 | 07:47 PM
DBear's Avatar
Cloud--
If it's not even cranking but the battery is good, try the ignitiion switch. They go out a lot, but they're only about 30 bucks from the dealer, and easy to install. In fact, when you get the cover panels off, take the switch out and see if you can start the car by putting a screwdriver in the slot and turning.
Old Feb 25, 2008 | 03:03 PM
dakkon880's Avatar
Could he just bypass everything by running power directly to the starter to see if it turn? Could see if its good at least...
Old Feb 25, 2008 | 03:36 PM
xtearitupx's Avatar
bump for last post
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
markevans999
Sep 10, 2015 04:29 PM
