97 MAXIMA TRANSMISSION
Old Feb 16, 2008 | 04:41 PM
2blue's Avatar
Is there different years that wont fit a 1997...auto?
Or all 95-99 auto trannys the same?
Also is there any other cars transmissions fit our car?
Old Feb 16, 2008 | 05:21 PM
pmohr's Avatar
No more Maximas...
95-99 are all the same with respect to the auto trans. You can use a 5th gen as well if you replace the VB.
Old Feb 16, 2008 | 08:45 PM
2blue's Avatar
Is the same transmission in the altima? What is the VB?
Old Feb 16, 2008 | 08:53 PM
pmohr's Avatar
No more Maximas...
I don't believe so, no.
Valve body.
Old Feb 17, 2008 | 07:12 PM
sparky1562's Avatar
Why do you have to replace the valve body?
Old Feb 17, 2008 | 07:24 PM
pmohr's Avatar
No more Maximas...
Not necessarily the VB itself, but the wiring harness for the A33 VB is different than the A32 version. If you replace just the solenoids, it may not be an issue.
Old Feb 18, 2008 | 05:41 AM
JtzMax's Avatar
Whatchyou say?
as for a 5spd ... 95 - 01 will fit if I recall correctly. Pmohr ???? I thought also that a Spec - V 6 spd would fit ... (with mods - same as a 6spd Maxima)
Old Feb 18, 2008 | 10:02 AM
pmohr's Avatar
No more Maximas...
Spec-V 6MT with the Maxima 6MT bellhousing will work, of course if you replace the trans mount, and do some tricky stuff with the clutch and flywheel setups.
But yes, 95-01.
Old Jul 25, 2012 | 11:59 AM
proveick's Avatar
Just put new quickstruts on the rear and new belts, 245K miles.
Would you flush the tranny at this point if it is running well or leave it alone?
Old Jul 25, 2012 | 12:47 PM
styliztik's Avatar
Struts and belts is not relevant to this thread? And with that many miles leave it alone if it's at. And fill as you need. If 5/6mt you can flush
Old Jul 25, 2012 | 02:16 PM
asand1's Avatar
Drain and fill is good. DO NOT FLUSH!! AT fluid has a service life, I don't understand why people say don't replace it. I guess its confusion of the term flush.
Old Jul 31, 2012 | 08:48 PM
JtzMax's Avatar
Whatchyou say?
4 yr old thread ..... really? And not even related to your question either, huh ...
Lakersallday24
Nov 7, 2024 07:31 PM
maxinout93
Oct 27, 2015 01:29 PM
cmpowell86
Aug 10, 2015 12:35 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
