VSS anyone have this problem???
Old Feb 20, 2008 | 10:48 PM
crensign's Avatar
i am getting a engine code for the VSS. sometimes going down the highway it will jump and sometimes it will not work at all.. big questions is.... Is the problem the VSS at the transmission or is it a problem at the ecu or cluster???
thank you
Chris
Old Feb 21, 2008 | 04:13 AM
fat_kid's Avatar
what will jump? the speedo needle?
edit:i have this problem sometimes, the speedo head needs to be replaced. I got quoted at $425 at a stealership to do it.
Old Feb 21, 2008 | 01:36 PM
crensign's Avatar
are you throwing a ECU code mine is throwing a code to replace the VSS Code : p0500
is this true in your case??
Chris
Old Feb 21, 2008 | 01:42 PM
DBear's Avatar
The usual drill is--(1) replace the VSS (it's on the tranny--only about $25), (2) tighten the screws on the back of the instrument cluster, then (3) replace the speedo (cluster). I ended up paying $40 for a used cluster from someone on the forum, and it's been fine since.
Old Feb 21, 2008 | 01:45 PM
crensign's Avatar
alright just wantted to make sure i am going to the dealer now to order it it is 25.02 plus tax and the ign switch that i need is 35.37 plus tax all seems like a fair price
chris
Old Feb 21, 2008 | 03:45 PM
fat_kid's Avatar
well, see i took my car in when it threw the VSS code and CEL was on and they said it was a lose wire, so they fixed it...supposedly. 2 weeks later CEL comes back on and NOW it turns out that the speedo head needs to be replaced. But then 2 weeks after that my CEL went off and even though my speedo is sometimes intermittent, when it stopes working I just tap heavily on the speedo cluster and that fixes it.
Old Nov 23, 2008 | 01:56 PM
rizzindriver89's Avatar
I really don't mean to hijack this thread but, I need some help here.
I love my max and do all the work myself so I want to know if the problem I have, can be fixed by me.
So my speedo tweaks out whenever I hit the freeway and go above 60 mph. Basically it'll jump like 5 mph up and down. Or it will go down to 0 briefly and then jump back up again. Now normally this wouldn't bother me but now its starting to dim my lights when ever it jumps. Kinda makes me feel that the car is going to die out.
Note. the speedo never "tweaks" when im doing city driving or going around 50mph.
I tried tightning the screws but to no avail. Someone please advise.
Thank you
Old Nov 23, 2008 | 03:42 PM
fat_kid's Avatar
just buy a used cluster and switch the speedos, easy fix
although it sounds like you have a loose connection somewhere on the harness, i would check that first and check the actual vss itself, make sure the connection is good
Old Nov 25, 2008 | 02:07 PM
vilmaxima's Avatar
what about the km's your new(used) speedo is gonna show? Where I live its illegal to switch the speedo(overall km's) to anything less than what you have(obv), but I wouldnt want it showing more that what I have either. Whats the solution to that(legally)? I had the p0500, and p0600, they are intermittent and I have tried about 3 different VSS's(in the tranny). I think if I fix the p0500, it wont throw the p0600 either.
Old Nov 25, 2008 | 02:08 PM
fat_kid's Avatar
don't tell anyone you did it....
Old Nov 26, 2008 | 12:55 PM
ptatohed's Avatar
Licensed to Spell
thank you
Chris
What is "it"?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
