Bypass A/C pulley
Old Feb 25, 2008 | 12:42 AM
MaxiiMa's Avatar
Bypass A/C pulley
i've got a 95 max and the a/c pulley is noisy. instead of replacing the pulley/compressor since it doesnt work anyways, i want to temporarily bypass it buy switching to the belt from a 95 maxima without a/c. this belt would be going over the alternator and the harmonic bal only. currently goes over harm bal, a/c pulley, alternator.
The question is, will the a/c pulley be in the way of this shorter belt? will i have to totally eliminate the a/c system inorder to do this?? can i just switch to a shoeter belt without any modifications???
I called a local dealer and he says that these maximas dont come without a/c according to his computer and the diagram which shows on their system.
I've got an FSM which shows pics of both setups side by side and are labeled with a/c and without a/c. so there has to be a belt somewhere... napa doesnt have it and can't order it either. where can i get this belt in Canada?? does anyone have a size of this belt so i can find a similar one of another vehicle...
i really need that a/c pulley to stop spinning... the noise is really annoying.
Old Feb 25, 2008 | 01:09 AM
pmohr's Avatar
No more Maximas...
We don't have a harmonic balancer, just a crank pulley.
No, it shouldn't get in the way.
Search, I've responded to at least 3 of these same exact threads myself. There are many posts about which belt number(s) to use when bypassing the compressor.
No A32 (USDM, at the very least) came without AC.
Old Feb 25, 2008 | 01:14 AM
CRiME's Avatar
oem ftw!
I used NAPA part #25-060355 (store location had to special order it) The belt model was 6PK903 and 920mm. It worked perfectly. My car is a 1995.
Old Feb 25, 2008 | 08:17 AM
Fr33way™'s Avatar
Wild for Width
What's odd is that even in the owner's manual it shows belt routing with and without A/C. I never got that, helpful I guess....
Old Feb 25, 2008 | 12:50 PM
cfiggs's Avatar
we have a parts place around here thats really good if you have any were you are its called carquest an theyve been helpful with my car
05' MaximaMan
Oct 8, 2017 06:36 PM
BkGreen97
Apr 2, 2016 05:47 AM
02PearlSE
Feb 1, 2016 12:37 AM
EdRomo86
Sep 12, 2015 07:49 PM
