Trouble Aligning Fog Lamp
Old Feb 26, 2008 | 05:16 PM
goldmax's Avatar
I tried adjusting my fog lamps according to the method in the FSM, but can't seem to get the fog lamps to adjust anywhere near where they need to be. The Stickies only show this option. The front end has never been damaged, so it's not an issue with body alignment, etc. Is there any easy way to tweak the mount to get the adjustment I need?
Old Feb 28, 2008 | 02:46 PM
drax89's Avatar
They arent high enuff? You on a flat surface with tires properly inflated?
Old Feb 28, 2008 | 03:34 PM
Snypa's Avatar
are you trying to point them to the ground or the shine "inline" with headlights and blend?
Old Feb 28, 2008 | 04:53 PM
goldmax's Avatar
Car is on a level surface, and I'm trying to aim them as described with in the factory manual - which shows the top of the beam being 4 inches lower than the center height of the fog lamp at 25 feet. I'm nowhere close to this...even at maximum adjustment, mine hit the ground a few feet in front of the bumper. I would like to get them to factory specs to fill in the area below the main lights.
Old Feb 28, 2008 | 05:55 PM
chirp the 1-2's Avatar
hmm i just installed my fogs tonight and didnt align them but they seem to be pretty even and add more light in the middle and alot on either side of the car. dont know if it helps but i do have the factory instructions if u wanna try that method. pm me if u do
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
