quick question
Old Mar 1, 2008 | 08:23 AM
driftmax's Avatar
quick question
would the throttle position sensor make a car miss, because when mine is plugged in it has slight misses, but when i plug it out it runs fine, but im not sure if its healthy for the car to run without it plugged in.
Old Mar 1, 2008 | 08:24 AM
njmaxseltd's Avatar
Are you getting a check engine light with a TPS code?
You can check the TPS with a multi meter and the Haynes shop manual.
Old Mar 5, 2008 | 06:32 AM
driftmax's Avatar
actually, I dont have any check engine light on, but the car has a slight miss when im crusing when the TPS is plugged in, so I plugged it out and the problem is gone, I have been driving with it plugged out. So I came to the conclusion that the TPS is not good, however I was just curious to know if the TPS when gone bad would make the car miss.
Old Mar 5, 2008 | 07:56 AM
Snypa's Avatar
instead of plugging it out, why not replace the piece.
Old Mar 5, 2008 | 08:31 AM
Take the advice in post #2. Then we'll take it from there.
Has your TPS ever been replaced/tinkered with? It's a very sensitive sensor.
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
