E-Brake boot
Old Mar 4, 2008 | 01:16 PM
ILLeSt MaX's Avatar
E-Brake boot
I recently order an e-brake boot from redlinegoods.com.
I just received the e-brake boot and I'm in the process of installing it. I'm lookin at the installation guide and it says to line up the metal rod with the boot. I didn't get a metal rod. Also, it says to insert the rod in the new boot, but it doesnt look like i'll be able to insert a rod in the new boot.. Can anyone help??
Old Mar 4, 2008 | 01:20 PM
LeVeL's Avatar
Metal rod as in under the handbrake lever?
Old Mar 4, 2008 | 02:44 PM
coachholland's Avatar
With just about all aftermarket boots out there, you have to keep the old metal wire from your old boot to install in the new boot. The only exception to this that I've found is a seller that has aftermarket leather ones with the wire frame already installed. I just purchased one myself and the quality is excellent on them. Only $30.
Old Mar 4, 2008 | 03:19 PM
ILLeSt MaX's Avatar
its the metal rod thats inside of the boot. I can't even get the metal rod out of the old brake boot. Any help?
Old Mar 4, 2008 | 04:02 PM
99BlackMaxMS's Avatar
Use a razor blade to cut it out of the old boot?
Old Mar 4, 2008 | 04:17 PM
ROCKART's Avatar
wants an I35
post up pics please when youre done
i am interested in gettin one of these
Old Mar 4, 2008 | 08:41 PM
ILLeSt MaX's Avatar
any idea on how to get the old metal rod in the new boot? im lookin at the installation instructions on redlinegoods.com and its not clear at all on how to get it in...
Old Mar 5, 2008 | 01:26 PM
lilaclucymaxima's Avatar
Team Ramrod
You find one of the cuts in the new boot, and push the metal rod through.
Old Mar 5, 2008 | 03:18 PM
ddurandd's Avatar
I recently bought one of these and had to re-use the wire from my old boot. I used a razor blade to cut the wire away from the old boot. You do not need to glue or attach the wire to the new boot. Just tuck the wire inside the new boot and press it into place from underneath the console. It will snug the new boot up against the console when you snap it into place. The fit is tight enough that it will not pull out.
Old Mar 5, 2008 | 04:04 PM
ILLeSt MaX's Avatar
thanx a lot for the information guys..
ill try this later 2nite and see where i can get with this...
Old Mar 5, 2008 | 04:09 PM
dutch078's Avatar
keep it metal
i actually used a wire coat hanger once for something like this, and that worked really well, too
knight_yyz
Nov 1, 2015 01:34 PM
londonflu
Sep 19, 2015 02:33 PM
followthadollar
Sep 17, 2015 06:31 PM
Bonka
Sep 14, 2015 11:18 PM
