Knocking noise under my feet. PLEASE HELP!
Old Mar 4, 2008 | 02:30 PM
kismias7's Avatar
I drive a 96 SE 5speed. recently Ive notice that after accelerating and letting off the gas, my car makes a knocking sound from, what sounds like, under my feet. I can also feel this problem slightly on the floor and in the pedals.
The problem started about two weeks ago and then went away after a night of driving. Now it is back, and it will not stop. The problem does occur while pressing the gas lightly or off the accelerator completley, but NEVER when on the gas hard.
Old Mar 4, 2008 | 02:35 PM
matty's Avatar
I had that problem and it wound up being the main nuts on the lower control arm were loosening up. Had to get new nuts from nissan with the plastic lock peice.
It could be really bad lower control arm bushings and there is alot of movement causing a knocking sound/feeling.
-matt
Old Mar 4, 2008 | 02:59 PM
Snypa's Avatar
yep something definately needs to be replaced/tightend or both.
Old Mar 4, 2008 | 04:06 PM
Delvin's Avatar
While you are doing whatever it takes to make the noise occur and you shift the weight of the car from side to side (slight swerving motion) does the noise come and go as the weight shifts from one side to another?? If so, you may have a bad bearing. I had the same problem before and there was no play at the wheel when doing the ol bearing shake test either. Just another suggestion let us know what happens.
Old Mar 4, 2008 | 06:10 PM
heynow's Avatar
check the LCAs. They're either loose or have bad bushings.
Old Mar 5, 2008 | 01:46 PM
ajcool2's Avatar
I had the same problem it was a bad wheel bearing.
Old Mar 5, 2008 | 03:36 PM
Schummy's Avatar
i have that problem right now!!its been bothering me for like 3 months....i think its something to do with the shifter linkage because when i move the shifter in gear,the rattle knocking gets louder or almost goes away..try to move it in gear not taking it out of gear but side to side...anyways goodluck kismias..
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
