Oil leak near firewall next to pulley. Need help identifying. Pics included
Old Mar 6, 2008 | 10:02 PM
Mxrider52's Avatar
I support for what?
Alright so I have an oil leak on the rear of the motor. Guess u would say next to the pulleys. I dunno what this thing is called so that why I am asking. I havent looked good, it been too cold, but I have noticed there has been oil on this for a while now and it looks to be getting worse. Now there is oil on my axle and well it has dripped down onto my LCA bushing.
I would like to look into fixing this so if anyone could tell me what this is or if it can even cause an oil leak that would be great.
Here the pics.
Old Mar 6, 2008 | 11:07 PM
WhiteMaxima9600's Avatar
That looks like powersteering fluid. And that is a picture of your powersteering pump btw. Unless it could be coming from your valve cover.
Old Mar 6, 2008 | 11:51 PM
mywhitewolf's Avatar
i doubt it. Pull out the power steering pump and replace all teh gaskets.
Old Mar 7, 2008 | 12:08 AM
Nealoc187's Avatar
SLOW
That's your power steering pump home slice.
Old Mar 7, 2008 | 04:33 AM
2da mizzax's Avatar
do a power steering system flush and use the lucas (only time i recommend anything lucas) ps sealer.
Old Mar 7, 2008 | 06:03 AM
ROCKART's Avatar
wants an I35
and any fluids on your LCA bushings will destroy them . i am going through that right now...
Old Mar 7, 2008 | 06:09 AM
max ride 41's Avatar
yuuupppp, power steering fluid, replaced my lca's last year cause of a line leak drippin down on the bushings. check the hose comin fron the resevoir, its about a foot and a half long, they dry up and its also under pressure so its your most likely suspect.
Old Mar 7, 2008 | 08:16 AM
Snypa's Avatar
you got the answer.....ps pump.so just check the connections now and get it fixed.did your fluid even look low.?
Old Mar 7, 2008 | 08:43 AM
Mxrider52's Avatar
I support for what?
Oh really? Well that cool I guess. I just thought it was oil. It still may be oil. I havent investigated it to much. I know I burn roughly 3/4 quart of oil say every 4K.
Yes I have checked all my fluids and the power steering fluid is never low. It has always been in between those 2 marks. With it all over the power steering pump and on my axle and bushing you really wouldnt think it would be power steering fluid considering there really isnt any missing from the reservoir. I know I have a minor leak under the reservoir but it not leaking enough to cause any damage. The hose just stays a bit wet at the top.
Guess I will rip the wheel off one day since it like 35 here now and was 60 here yesterday and I will take a look. Id like to get this fixed. I hate knowing there problems with my car.
Here 2 more pics.
Old Mar 8, 2008 | 12:30 PM
97 joe's Avatar
its not the power steering i have the same problem on my 97 and im thinking its the valve cover
im replacing both of them soon ill let you kno wat happens with that
Old Mar 8, 2008 | 03:16 PM
Love_00_Max's Avatar
I have the very same problem with the PS pump wet and none of the hoses leaking. I am sure it isn't PSF since there is an unique smell to the it vs engine oil.
I am suspecting it is engine oil though I haven't had a chance to root cause the leak. I am due for an oil change so I will check it again and see what is exactly happening under there next weekend.
Old Mar 8, 2008 | 04:56 PM
andrei3333's Avatar
right for some unknown reasons to mankind the PSF in OUR cars smells exactly like some Dexron III auto tranny fluid
Old Mar 8, 2008 | 07:09 PM
That's what I meant too.. Also recently I did a PS flush with Mobil1 ATF, so I know the fluid is new, and since there is no decrease in levels in the reservior, I am beginning to wonder if it is PS fluid in the first place.
I am leaning towards engine oil but I will know for sure next weekend when I get there and spend more time analysing the leak.
Old Mar 9, 2008 | 04:17 PM
OK. I got down under my car and I see the leak from the engine. It is almost certainly where the tranny meets the engine and I am leaning towards the rear main seal. Anyway, RMS leaks are quite common on high mileage cars, one cannot get away from it, it is going to happen sooner or later on high mileage vehicles.
The part is cheap something like $25 but the labor is too expensive. Don't know if it is worth $700 for fixing a $25 part?
Old Mar 31, 2008 | 01:48 PM
Scott LaRock's Avatar
I have the same leak, how hard is it to change the PSP?
Old Oct 22, 2008 | 11:10 AM
MaximusTheGreat's Avatar
I've got exact same leak same place on PS pump 170,000 miles don't know where it's coming from. My PS fluid isnt low. It looks like oil.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
rtirbany
Sep 8, 2015 11:46 AM
95Maxi
35
Sep 2, 2015 10:37 AM
scarletsosa
Aug 17, 2015 09:09 PM
