Painting calipers
Painting calipers
Yes, there is a link in the FAQ, but it contains NO information and the pictures are 100x100 px or so...
Mainly I'm wondering, how hard is it to paint the calipers? I expect the hardest part is taking them off and putting them back on afterwards? Is there anything I should know about what not to paint/ what to paint if I do this?
You don't have to take them off and put them back on. You can buy a kit that is brush on, G2 caliper paint kit. I've used them before and will use them again.
Good price here: http://www.wheelskin.com/g2_brake_caliper_paint.html
I got mine at Pep Boys for $15. One little can will allow you to paint all four of your calipers easily and will leave you with plenty left over for more coats in the future.
Just tape it off and spray. Dont worry about the paint getting places. It will burn off or rub off any part its not supposed to.
i just used making tape to tape up the rotor real good. use a wire brush and attach it to a cordless drill to brush off all dirt on the calipers and around the outer area of the rotor.then use a little soap and water to wash down the areas you want to paint. then use a primer (dont really have to but i did anyway) bout two coats allow bout 5 min between coats. then get high temp engine spray paint what ever color you desire. go about 3 or 4 coats,i then used clear coat and your good to go.just take your time and it will come out nice.
I am going to do this over my spring break. I am putting on SS brake lines so I thought about just taking the caliper and bracket off to get a clean job done on them. It will take longer but I'll be happy with the results.
-Mooney
-Mooney
Heres my write up.
1. jack up front of car.
2. take off front wheels
3. Spray brake cleaner on calipers, let dry.
4. put paper around fenders so yu don't get back spray.
5. paint them suckaz.
6. put wheels on and speed around until they are dry. yay!
Should take you 30 min at the very maximum.
Heres my write up.
FOR A HACK JOB....
here's how i did it for my buddy's vr6 jetta and my max..
#remember to read directions and follow all safety procedures (i am not responsible for idiocy#
1) jack up car, pull wheels off
2) remove calipers and 'brackets'
3) use duct tape and cover hose ends, then take a baggie and cover tape (make sure its tight).. then zip tie the baggie secure, tape hose up on strut
4a) compress pistons, remove bleeder, find bolts to plug bleeder hole etc..
4b) compress pistons, get extra bleeder valves ( approx. $10 ea.), plug open holes
5) sand blast (i use 80grit glass bead)
*if your calipers were painted b4 then chip off old paint, or use propane torch and heat caliper (!wear gloves to handle!) then s'blast*
6) clean up with brake clean, or wax and grease remover
7) mask off piston and other areas you dont want to paint
8) spray light coats of color (make sure to read directions if you dont know how to paint!)
9) once done with color, spray desired amount of clear coat (again in light coats)
10) let paint CURE (not just dry to touch/handle) (i use duplicolor and total cure time is 7 days, i call it good at 5 with a 40k btu heater in garage)
11) reinstall remembering to regrease slide pins etc..
**OR**
-use same steps as above, but replacing steps 5 and 6 with aircraft paint stripper (read directions and use proper safety as stated)
it does take some time but well worth the great result. hope this helps.
**OR**
"silver ******"? is that the color you painted yours? I've heard of people painting theirs the OEM Nissan color Radiant Silver but never silver ******.... Did you get that color from Pep Boys or from your mom?
ok 1st of 96blackmaxSE calm down. also you should sand it down because painting ontop of dirt and rust is just pointless.I plan on doing this on the max in a few weeks when it warms up. A nice black with a few clear coats on top to give it a ncie shine. sure i have stock breaks. but that doesnt mean they need to look ugly
this is what my calipers look like through my rim as of now
ROFL... Who you calling Noob? You've got a whopping 20 years of experience in life you Noob! In a few years, when you're my age and off your mama's tit, you'll look back and realize what a complete waste it all was to paint your fugly, stock calipers. Grow up, be a real man and do the 4 piston Z caliper mod and have something that not only looks good but performs well. Painting stock ones is like putting perfume on a pig... or perfume on your mom.
Get lost.
B-no. I have never seen or heard of a caliper a'ss f'ucking another caliper. (please keep your immaturity to yourself)
C-maybe for you but I like being proud of what I drive.
D-i think twostepping jimi and you should have a play date.
2. waist = waste
3. I don't think a subtle color like black, or even silver, is RICE, etc....
You're right, no need to SHOW OFF stock calipers, but thats not the goal here...I'm sorry that I don't want to have rusty/dirty calipers.
Id rather paint them black so they don't look sh!tty, but will not be popping out saying "look at meeeee I'm stock!!"
and black_maxed is right...last time I checked, my calipers did not have a sexual orientation.
1. That's your opinion.
2. waist = waste
2. waist = waste
Good day kid.
are you by chance a trolling SOB who tries to instigate people based on their opinions? while none of the characteristics you labeled me with are correct, that's irrelevant. I was making a point about the time and energy in terms of this project as opposed to a different one. I wasn't complaining about the work in general. For instance giving the car a wax job or degreasing the engine or another task that has a comparable work load and cost yet has higher returns because it's not pointless like painting brakes. Go wack some moles at the arcade or smoke a bowl and chill out. What would your Max say if she knew you were so ill-tempered.
Thank you. GTFO.
), its suppose to be a how-to thread as that was the original question.and guryon...you should keep the SOB'n to yourself. you are the one that needs to chill out, and its better to make friends than enemies if you plan on getting future help from this site.
WHY BREMBO PAINT THEIRS CALIPERS, 2008 IS FOR COLOR,DO IT DUDE WIL LOOK GOOD,EVERY BIG BRAKES KIT COMES IN DIFFERENT COLORS NOW BACK IN 8O'S WERE NOT SO PEOPLE STUCK IN 80' IS NOT YOUR PROBLEM,I THINK IS A GOOD MOD.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
