Which O2 sensor is it?
Old Mar 20, 2008 | 08:29 PM
goldmax's Avatar
I threw a code today on the way home from work. Pulled the code manually off the computer and it read 0303 - left bank O2 sensor. Which one is it? I was thinking the one that is accessible under the left front wheel well, but the parts picture from Courtesy Nissan makes it look like the front one is the LH or driver's side sensor. Also...is factory the best way to go to get the entire harness and not have to splice anything? I was going to look at motivate.ca, but the site is down or gone. Any help would be appreciated.
Old Mar 20, 2008 | 08:44 PM
CRiME's Avatar
oem ftw!
Here's a diagram that should clear things up:
I replaced mine with universal sensors which did require splicing, and everything has been great for 2+ years now. OEM sensors with the harness would obviously be the easier and preferred choice if you don't mind spending a little more. The best place to buy the sensors is www.oxygensensors.com
The site is still up, but you may have mistyped it. the URL is http://www.motorvate.ca
Old Mar 20, 2008 | 08:53 PM
black_maxed95's Avatar
ya its the sensor closest to the radiator. I just buy the bosch universal ones and splice them. Ive found them for $35 on ebay new.
Old Mar 20, 2008 | 09:03 PM
Snypa's Avatar
sensor behind rad
Old Mar 21, 2008 | 04:27 AM
titanbk's Avatar
sorry to give you some crap about this but isnt a p0303 a misfire cylinder 3?
Old Mar 21, 2008 | 04:29 AM
pmohr's Avatar
No more Maximas...
P0303 is, yes.
Old Mar 21, 2008 | 06:04 PM
jzack's Avatar
FYI - Sometimes the O2s just get carbon build-up and don't need to be replaced. Have had this issue on and off with our Maxi. Removing sensor, cleaning with Gumout and replacing sometimes solves it? If not - then just replace it...
Old Mar 22, 2008 | 07:19 AM
titanbk's Avatar
well guys if he has a p0303 then this issue has nothing to do with the 02 sensor, he would need to start looking at cylinder 3. Maybe I am reading his post wrong. A bit confused at the moment.
Old Mar 22, 2008 | 09:32 AM
CRiME's Avatar
oem ftw!
In his post he said that he pulled the codes manually, meaning he didn't go to autozone or whatever, he used the screwdriver and counted the flashes - 3 long, 3 short = front left o2 sensor.
Old Mar 22, 2008 | 09:37 AM
tbergma1's Avatar
If it actually tells you which cylinder, it going to be the coilpack. Test it with the ohm meter. Better yet, i would switch it with another cylinder and see if the problem follows it.
Old Mar 22, 2008 | 09:52 AM
CRiME's Avatar
oem ftw!
He doesn't have a coil problem. 0303 and P0303 are not the same.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
