Check engine light is blinking while the car is running...WTF?
Old Mar 22, 2008 | 08:34 AM
DuMKuH's Avatar
Hey, guys, I changed the radiator yesterday, flashed the ECU and everything. And today, when I was driving, the check engine light started to blink while the car is running. What does that mean? Any help is greatly appreciated. Thank you.
Dima
Old Mar 22, 2008 | 08:57 AM
tbergma1's Avatar
You have to pull your codes. See what it is. Do you need to know how to do that?
Old Mar 22, 2008 | 09:09 AM
Divewjason's Avatar
Maybe it's a misfire?
96blackmaxSE's Avatar
boost me.....
Mutiple cylinder misfire! FTML!!
Old Mar 22, 2008 | 09:13 AM
tbergma1's Avatar
My oring failed on one of my fuel inj. It started dumping all kinds of fuel down the cylinder and my cel started flashing also. But pulling your codes is the best bet.
Old Mar 22, 2008 | 12:25 PM
riceyasian86's Avatar
Probably a misfire
Old Mar 22, 2008 | 01:08 PM
icedout's Avatar
+1 on the misfire
Old Mar 22, 2008 | 01:42 PM
G4nismo's Avatar
http://vbxmaxima.8m.com/ecudecoder.html
Old Mar 22, 2008 | 06:27 PM
Snypa's Avatar
misterfire.!!!
Old Mar 22, 2008 | 07:47 PM
RacerX1320's Avatar
Deff misfire meng. You should also feel the car become a bit sluggish too and the exhaust note changes.
Old Mar 22, 2008 | 08:42 PM
pmohr's Avatar
No more Maximas...
It's not 'probably' a misfire when the CEL flashes. Codes may or may not tell which cylinder it's on. Is it missing consistently at idle? Start unplugging coils, pinpoint the specific cylinder.
What do you mean you 'flashed' the ECU when you installed your new radiator?
Old Mar 22, 2008 | 09:17 PM
While the CEL was blinking did your engine feel like it was having a hard vibration or a studder? If so I will say it's a cylinder misfire. Go to a smog shop and ask to have your codes checked.
Old Mar 23, 2008 | 12:09 PM
NmexMAX's Avatar
dot dot dot ...
MCM. Multiple Cylinder Misfire. Coil packs.
Old Mar 24, 2008 | 05:27 PM
dpassino's Avatar
I just had this same problem. CEL started blinking, and car making wierd exhaust noises, as well as really bad stuttering like it wanted to stall, but never did.
Got the code from Autozone, Cylinder 4 misfire. I changed the coil pack, All better.
Old Mar 26, 2008 | 11:51 AM
dmilamj's Avatar
Homie
Blinking CEL
From the FSM, EC-192:
"When a misfire is detected which will overheat and damage the three way catalyst, the malfunction indicator lamp (MIL) will start blinking..If the misfire frequency decreases to a level that will not damage the three way catalyst, the MIL will change from blinking to lighting up..."
So that's why your CEL is blinking. The misfire is bad enough to damage your catalyst.
Lakersallday24
Jun 16, 2019 01:35 AM
Flores94
Aug 11, 2015 12:53 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
bassmann
Aug 3, 2015 07:53 PM
