shifter broke at base!!!
Old Mar 28, 2008 | 07:35 PM
NElsonAQuino's Avatar
so as i was going home my shifter snapped when i shifted in to second??!?! i must be too strong or it could be the cheap metal ebay uses but it snapped and now its stuck in neutral. is there anyway i can throw it in gear so i can drive it less then 100 yards to the closest mechanic. and pushing is not an option becuase i have to go all up hill. can i go under the car and shift it in gear or something. any gear will do..
Old Mar 28, 2008 | 07:43 PM
pmohr's Avatar
No more Maximas...
Go under the car, find where the shift rods enter the trans. Shift it into first, done.
eBay STS? It's happened before. You get what you pay for.
MorpheusZero's Avatar
Ugh
Get under the car
Unscrew the cat
Remove the cat heat shield
Have a buddy depress the clutch (optional)
Grab the bottom of the shift lever (attached to the shift linkage), push it towards the driver's side of the car and pull it towards the back of the car
Some cheapo ebay shifters have had this problem before, the shifter snaps because it's cheaply made.
Edit: Guess you could do it at the tranny too
Old Mar 29, 2008 | 08:22 AM
mtrai760's Avatar
'Trynna' is not a word
Ebay knockoff's FTL!
Old Mar 29, 2008 | 08:51 AM
JtzMax's Avatar
Whatchyou say?
how long have you had your sifter ???? are you hard on it, does it take effort to get your car into gear?????? I'm sortta curious (other than it being chep ebay junk) why it broke, I have a cheapy STS and it seams fine. well ... so far. lol
Old Mar 29, 2008 | 04:59 PM
Product_Of_Korea's Avatar
i almost bought one of those glad that i didnt. I just took the angle grinder to the shifter and took off a couple of inches
Old Jun 9, 2008 | 06:33 PM
97_Max's Avatar
I dont know why I did this but I took the screws out of my shifter and the **** fell out. I put everything back together but now I cant get my key out the ignition. What should I do?
Old Jun 9, 2008 | 08:00 PM
arrocha87's Avatar
how has it worked for u? am i right to assume u have o use an aftermaket **** with the lil set screws cuz u dont have thread
Old Jun 9, 2008 | 08:01 PM
f550maranello2's Avatar
i recently cut my stocker to 7 inches.... from the top of the ball .... i cut some 3 or 4 inches out of it and welded the tip back on.. i feels great
Old Jun 9, 2008 | 08:50 PM
QNO_A32's Avatar
dont get OBX from ebay. i had to "modify" just about everything to get it to my liking...
Old Jun 9, 2008 | 08:58 PM
95maxdvt
Sawzall and aftermarket **** with allen screws lol
Cut it down all those shift ***** come with the plastic inserts w/ diff sizes and they just clamp on w/ the allen screws. Free and still shortening the throw thats the point right?? Why do you need to shift that rough anyway??
I can hit 2nd and 3rd quick enough to chirp the tires with stock shifter and no crunching or snapping shifters lol.
Old Jun 9, 2008 | 09:46 PM
MaximaSpd85's Avatar
my shift **** just presses on
Old Jun 9, 2008 | 10:31 PM
Snypa's Avatar
Be careful man.You might just be next.
Old Jun 10, 2008 | 11:54 AM
JtzMax's Avatar
Whatchyou say?
^^^ I sure as he!! hope not mate! lol I've been dealing with a lot of things already and that is the last thing I need. I wonder if I still have my OEM laying around?
Old Jun 10, 2008 | 07:41 PM
pahaf's Avatar
how many times has it flew off when you shifted? lol
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
magiconthetire
Oct 26, 2015 09:03 PM
atriuum
Sep 28, 2015 01:19 PM
