1000 rpm when the gear is "N" or "P"???
Old Mar 29, 2008 | 08:33 AM
hermtm2's Avatar
Hi.
My 96' I30 has auto tranny. I realize that the idle of my I30 is so high which is 1000 rpm at "N" or "P" and 650-700 rpm at "D". I couldn't find any vacuum leak. I heard that the normal idle should be 700-750 rpm when the gear is "N". How to adjust the rpm as normal speed?
Thanks.
Old Mar 29, 2008 | 08:35 AM
EnervinE's Avatar
i has college
Are these the RPMs when the car is fully warmed up?
Old Mar 29, 2008 | 08:37 AM
tack86's Avatar
my is over 1k when is cold, then drop back to around 700 when it is warm
Old Mar 29, 2008 | 08:42 AM
hermtm2's Avatar
Yes, it is at fully warmed up. When the engine is started, rpm is about 1500 then back to 1000 rpm.
Old Mar 29, 2008 | 08:58 AM
MOHFpro90's Avatar
I vote vacuum leak.
Do the rpms jump up and down at all?
Old Mar 29, 2008 | 10:38 AM
Rocky123's Avatar
i think the A/t is little different between manual,i have manual 95 and cold is 1500 and warm is 650.,thats one thing...with air.i dont know the word..sorry for my eng.i m czech..air filter and right behind air sensor..is.
Old Mar 29, 2008 | 10:58 AM
bigpulve+'s Avatar
Thats pretty normal. At fully warmed up my RPMs in neutral will sit right around 900 and in drive and reverse they sit at 650.
Old Mar 29, 2008 | 12:03 PM
99grnmaxgxe's Avatar
Do you have an codes? I'm also guessing vacuum leak. But I had this symptom when the TPS went bad.
Old Mar 29, 2008 | 03:26 PM
hermtm2's Avatar
I don't have any code. I adusted the rpm from 1000 to 750 by adjusting bolt on the throttle body. There is a grey plastic nut.
Old Mar 29, 2008 | 03:44 PM
Snypa's Avatar
check your tps.
Old Mar 29, 2008 | 11:28 PM
vqmaxman's Avatar
It's normal don't worry about the high RPMs. If there are no CELs no need to worry.
Old Mar 30, 2008 | 06:16 AM
njmaxseltd's Avatar
The default throttle body idle should be set to 600-650 with the TPS disconnected.
Start the car and warm it up completely, drive around for 10 minutes.
Turn the car off, disconnect the TPS.
Restart
Adjust the throttle body set screw (NOT THE IACV) to obtain an idle speed of around 600-650, all accessories off, headlights off, car in park or neutral.
Turn off the car and reconnect the TPS.
Restart and check idle speed. It should be around 750, if it's not adjust the idle speed at the IACV, do not touch the throttle body setting.
Old Mar 30, 2008 | 12:02 PM
hermtm2's Avatar
I got CEL this morning. It is 0400: EGR valve malfuction.
Old Mar 30, 2008 | 01:25 PM
Snypa's Avatar
there ya go !!!
Old Mar 30, 2008 | 03:52 PM
Crusher103's Avatar
ya i was going to say its normal it will do the same even after the egr problem is taken care of, my auto idles at 1000-900rpm in park or nuetral, my car idles at 500 in D thou
Old Apr 2, 2008 | 01:50 PM
hermtm2's Avatar
what (Where) is the throttle body set screw (NOT THE IACV)? I think the grey color screw, which I turned to adjust idle, is on the IACV. Now 750 rpm when "netural" or "Parking" and 600 rpm at the "Driving"
Thanks.
Old Apr 2, 2008 | 02:06 PM
LeVeL's Avatar
I've noticed that sitting at a red light, for example, if I shift from D into N the revs go up slightly.
Old Apr 3, 2008 | 06:15 PM
MOHFpro90's Avatar
They would...less load on the motor?
Old Apr 3, 2008 | 06:24 PM
caseymaxima's Avatar
Restart
Where in NJ are you? Do you want to adjust the idle on my 96?
Zack
Old Apr 4, 2008 | 09:01 AM
hermtm2's Avatar
I live in Lansing, MI. I really need to adjust the idle on my I30.
Thanks.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
