Fog lamp help!!!
Old Mar 29, 2008 | 09:38 AM
tack86's Avatar
Fog lamp help!!!
Hi there everyone,
I have a 97 max and recently bought a headlight stalk with fog switch, fog lamp (both sides), and a relay for the fog,
I install the headlight stalk and all lights are working but the fog, and yes i did turn on the head lights first, and i also install the relay, and also install a fog light fuse, connected all wires, and fog will not turn on.
I do not have the SE, but does comes with pre-wires for fogs(GXE)
another thing, I can hear click sounds from the reply and i turn on and off the fog switch..
any advice would help thank you
again thank you all in advanced
Old Mar 29, 2008 | 12:03 PM
2muchbass's Avatar
wanna sell your fogs?
Old Mar 29, 2008 | 03:01 PM
Nopike's Avatar
Sounds like you may be missing Fuse #63 (15 Amp). This fuse is only used for fog lamps so maybe it was not installed? Did you install this fuse? In the correct socket? Are you getting 12VDC to the fog lamps?
Old Mar 29, 2008 | 03:03 PM
Nopike's Avatar
Otherwise check if you are getting 12VDC to the Orange with Black stripe wire of the fog lamps.
Old Mar 29, 2008 | 03:47 PM
tack86's Avatar
ya i have check the fog fuse, it is installed, its a 15A fuse.
and I will check the voltage 2morrow when I get a chance,
just a heads up, what if i do not get any voltage on the orange with black stripe?
but thank you for the advice,
Old Mar 29, 2008 | 09:52 PM
Nopike's Avatar
Check for orange/blk wire at fog relay lamp relay make sure it is there. check for 12VDC at solid orange wire at relay. It would make more sense if I could post the wiring diagram but not sure how to post image. I'll try and figure out tomorrow.
Old Mar 29, 2008 | 10:06 PM
Nopike's Avatar
Orange wire provides 12VDC from the fuse (#63) to the contacts of the fog lamp relay, when relay is closed (turned on) it provides 12VDC to Orange/blk wire at relay contact over to the fog lamps.
Other terminal at fog lamp (soild black wire) must be grounded to complete lamp circuit.
Old Mar 30, 2008 | 05:38 AM
Nopike's Avatar
Bat + -- Fuse 63 -----------------------_____-------------------------------------- Lamp ------------ Grnd.
12VDC ************ Orange **** Relay contact **** Orange/Blk ******************Black wire
Maybe that helps, looks like 12VDC is not getting to your lamp. Sounds like your Fog lamp relay is closing so that part of circuit is OK. Are you sure the relay is the correct type? Make sure fuse was inserted into #63 slot.
Old Mar 30, 2008 | 10:23 AM
tack86's Avatar
ok ill double check with everything later today, as im at work right now,
again, thank you
Old Mar 30, 2008 | 10:25 AM
tack86's Avatar
and no, unless i cant get it to work at any cost
Old Mar 30, 2008 | 06:14 PM
tack86's Avatar
i have tested today again, and somehow it is working now,
i think it might be the bad ground, because i do get 12v at the wires where you plug in your fogs.
thank you again for your help Nopike
Old Mar 30, 2008 | 06:16 PM
Nopike's Avatar
You are welcome. Good luck.
Old Mar 30, 2008 | 06:20 PM
Nopike's Avatar
If the 12VDC is at the fog lamp and they don't work than I would suspect a bad ground or a bad connection at the lamp. If 12VDC is missing at the lamp then you have to work your way back toward relay and fuse.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
