DTC 0509, confused after searching
Old Apr 6, 2008 | 06:50 PM
martells2's Avatar
I pulled this code about two weeks ago. Ever since then, I've been searching the boards to see what the solution is. I know the actual code means high voltage on the front 02 sensor. However, in the threads I searched, some said it was the MAF that would cause this, others said it was the ECTS, and I think only one person actually said to replace the 02 sensor. So I'm lost as to what to try first. Basically the car would stall on start up when its cold out on first try only, it has stuttering at WOT above 3k or if you try and accelerate from 1k. Sounds like it's missing and the exhaust "pops". If you keep you hand at the muffler, you can feel bursts of air as it makes the popping sound and rpms drop with each pop. Trying to get this straightened out, and searching has only confused me. Should I just order the 02 sensor and start there? 0509 is the only code it's throwing. Thanks!
Old Apr 6, 2008 | 07:07 PM
pmohr's Avatar
No more Maximas...
What year is your car?
O2 sensor codes usually can only be caused by the sensor itself, for the upstreams at least.
If your car is misfiring, chances are it's the coils; they seem prone to failure (especially in the '99s, if they've not been replaced).
Old Apr 6, 2008 | 07:10 PM
martells2's Avatar
It a model year of 98, with a production date of 07/97. So should I look into replacing coils as opposed to the sensor itself? Thanks pmorh!
Old Apr 6, 2008 | 07:28 PM
pmohr's Avatar
No more Maximas...
Short of a wiring fault, or your ECU crapping out, they're going to be two seperate problems.
Old Apr 6, 2008 | 07:36 PM
martells2's Avatar
so start with the 02 sensor, and be prepared to move onto something else like coil(s)?
Old Apr 6, 2008 | 08:01 PM
pmohr's Avatar
No more Maximas...
Personally I'd start with driveability problems first (misfiring), not O2 issues.
Old Apr 7, 2008 | 12:34 PM
Snypa's Avatar
Check 6-pack.
Old Apr 7, 2008 | 02:23 PM
martells2's Avatar
Originally Posted by Snypa
Check 6-pack.
is that a website or do you mean the 6 coils? I've already got a set of used ones I'm going to try and use at the end of the week.
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
bigdogsteve
Jan 31, 2018 04:18 PM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
