Can I remove the silenser?
Old Oct 31, 2001 | 04:21 PM
190hpKiLLA's Avatar
Granny Driven
Can I remove the silenser under the battery that is part of the intake? What does it do? I aslo want to add a tube to the intake. Thanks.
Old Oct 31, 2001 | 04:27 PM
Toolrocks's Avatar
Re: Can I remove the silenser?
Yes you can. I did it to mine and felt like I had more power on the top end. It also doesn't make it any louder. I also thought about routing air from underneath the front of the car towards the opening created by removing the resonator but never got around to it. I eventually got a stillen intake. A word of caution - if you do route air from the front of the car to the new opening I'd maybe consider what might happen if you drove in heavy rain. I don't think you'd hydrolock the engine but I probably wouldn't connect the tubing, I'd just direct the cold air towards the opening. Let me know if you have any success.
Old Oct 31, 2001 | 04:30 PM
190hpKiLLA's Avatar
Granny Driven
Re: Re: Can I remove the silenser?
Good point I will keep that in mind. I will probably put it some where higher.
Old Oct 31, 2001 | 06:28 PM
cjrj473's Avatar
I removed both of the resonators and it gave the engine a deeper growl i thought but i couldnt tell any difference in power. The second one, off the little wedge thingy between the MAF and TB, made a bigger difference but you have to plug it somehow. I also looked at routing air from under the car but on mine the inlet into the main intake tube seems to make any air that goes into the intake that way go in the opposite direction of the airflow, so i didnt do anything with it.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
