Changing Trans Pan gasket
Old Apr 11, 2008 | 09:25 AM
crsdsabers's Avatar
Hi,
I searched the forums and couldn't find an answer. I'm changing a leaking trans pan gasket tonight and have the gasket. It's rubber and I'm not sure if I should use gasket sealant w/ a rubber gasket or not?
Any suggestions?
Thanks,
JEC
Old Apr 11, 2008 | 10:07 AM
Fasteddie01's Avatar
I tried the search function and found some threads about trans, but nothing specific about gasket sealant. I would guess no mention means no prob. Found this thread with a bunch of pics etc. http://forums.maxima.org/showthread....mission+gasket
Just search in Fluids forum for more info.
Old Apr 11, 2008 | 10:50 AM
crsdsabers's Avatar
OK, thanks for your help. I'll leave out the sealant (except to keep it aligned when I'm attaching the pan).
Again, thanks,
Jeff
Old Apr 11, 2008 | 02:09 PM
njmaxseltd's Avatar
I didn't use any sealant when I replaced mine, many years back, no leaks yet...
Old Apr 11, 2008 | 02:20 PM
pmohr's Avatar
No more Maximas...
Same here, though I usually put a small bead of RTV around the corners, both above and underneath the gasket. Helps it stay in place, and ensures a seal around the corner (same principle as the RTV on the sharp corner on the valve cover gasket, just a much more gradual turn).
kjlouis
Oct 3, 2015 05:29 AM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
iamute
Sep 20, 2015 05:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
