whining noise coming from engine ....
yup i bought another 4th gen a few weeks back, some of you may rember my burgundy 5.5 gen.
But heres my prob with the 4thgen, i noticed the engine whines bad, and no theres no S/C....
It does sound like its coming from the pullies. what should i check? / replace??
belt tensioner? alti pulley ??
and sugestions would be cool ,thanks
check your alternator and also the AC compressor. I hit a bad puddle one day in mine, and the following day I had a whine that resembled the noise of a failing alternator. I narrowed it down to the AC compressor and i bypassed it for now with a shorter belt.
this may sound silly , but anything i can spray to maybe give it as a temp fix for a week or 2,
wd-40 or something ?
i just simply dont have the time to fix it but dont want anything to break...
If it's a high pitch squeal then it's likely the belt just needing to be tightened. If it's more of a metallic whine/hiss noise then it's the compressor. Not sure what model year yours is, but if it's a 97-99, I can give you the info where you can get a remanufactured one for $175+shipping. Great seller and it's $150-200 less than autozone or advanced remanufactured ones. I think I got the last 95-96 he had, but I can check with him to be sure if needed.
it is clearly a whine type noise....
but it doesnt change when i turn the ac on or off....??
still the compressor?
tried spraying everything ith wd but it didnt help....
I forget which model (97-98) It was but If I choose It was a 98 with the alternator problems or recalls. I am sure this Is the symptom of a bad alternator and It's probally on it's last legs.
Does the whine sound like a faint s/c,If so It Is more likely the alternator and It's about to go out on you.
and the car take a long second or two too start latly.......
It could also be the a/c idler pulley assembly, I have a whinning noise as well on my maxima and I just recieved my replacement idler pulley. I will be putting it on tomorrow I will let you know if that takes care of the whinning noise.
Good luck with the new car and enjoy.
Take a long pole and stick up against alternator see if you here the noise go through the pole. Then put it up against the compressor. My old car was making a whine from the alternator even though it was still working fine and it sounded like I had a S/C. I got it replaced just in case.
check the alternator, best way is to take off the belt start the car see if the noise is still present but i had that problem on my 96 and 99 max made whinning, hollowing n noise before it went on me. My brothers i30 has that problem now just have to change the alternator.
its not realy pausing , but it seems like its taking alot more cranks to start then it should .(and its not like its cold or anything anymore in CT...)
it was the alternator....
the noise got real bad, i removed the belt.
tensioner as good.
then i go to spin the alti pulley and was so hard to spin! ! it as siezed up bad !
new alit i gotta say was a pita to put in , i wish i had inspector gadget to help me out but I got it...
thanks bros !
tensioner as good.
thanks bros !
Wow. I had this happen last night for the first time. Totally sounds like a faint supercharger too. Am glad I found this thread. I'll do the screwdriver to the ear listening method, but it sounds exactly the way maxspeed96CT described it.
Any suggestions on the best/cheapest alternator? Should I buy only Nissan parts for this, or is it a Kragen/Checker/Shucks special?
I had a bad experience with a Kragen alternator on an old Acura once.
I just got this whine today. Was odd, I drove to the supermarket and it was running normal then I get out and go to drive home and the whine started as soon as I started it. Struck me a little odd that it didn't build up over time, it just happened.
I haven't had the chance to check and confirm it's the alternator, but it was my main suspect even before I looked at this thread. Mainly because my headlights don't seem as bright as they once were. I'll be popping the bonnet tomorrow and seeing what I can find...
Hondarydr
Dec 30, 2024 06:15 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
Starrider
Sep 17, 2015 07:26 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
