Q45/J30 Caliper Fitting
Old 04-11-2008, 01:46 PM
Stock Airbox Supporter #3
aporozco's Avatar
excuse me for beating this to death but i have searched and did not find the answer to my question.
Will the Q45 calipers fit directly onto the spindle? I know the J30s will. I know they are very similar but i need to order some and want to know which ones to order.
Also I know that I need to milll down the rotor, so where can I take them to be Milled? Someone said Naapa does not do that. THanks ya'll
aporozco is offline
Old 04-13-2008, 05:25 PM
aporozco's Avatar
Anyone have any idea?
aporozco is offline
Old 04-13-2008, 06:26 PM
Former Vendor
BLACKonBLACK98's Avatar
they will both fit but i would reccomend the j30 calipers. they both have the same mechanical specs but the j30 are physically smaller/lighter from the research i did.
BLACKonBLACK98 is offline
Old 04-13-2008, 06:30 PM
speed racer's Avatar
You need the torque member for either application.
speed racer is offline
Old 04-13-2008, 06:57 PM
Former Vendor
yeah... definitely order a loaded caliper. i had a horrible time trying to find the pad holders.
Old 04-13-2008, 07:17 PM
SLOW
Nealoc187's Avatar
If you use the maxima torque member with the J30 caliper then all you have to do is a bit of grinding on the max torque member OR make a 1/16" or so spacer and do an even smaller amount of grinding on the max torque member, and you don't have to go through milling the rotors. Alternatively if you mill down the rotors you can use the J30 torque member and avoid doing the grinding on the torque member. Personally I'd do a little grinding on the torque member rather than losing 6-8mm off of the already small diameter rotors.
Read this thread
http://forums.maxima.org/showthread....&highlight=j30
We did this exact same setup on a 4th gen and the procedure was identical.
Nealoc187 is offline
Old 04-13-2008, 10:21 PM
aporozco's Avatar
thanks nealoc. i feel like i wanna jjust get the 300zx BBK. it easier, but i need to find some cheap calipers. and do i really need a hub ring if i do the BBK?
aporozco is offline
Old 04-13-2008, 10:28 PM
SLOW
Nealoc187's Avatar
i wouldn't say 300zx is easier, it's just different. you need to use different brake lines with the 300zx brake calipers or else you run the risk of ruining the calipers, still need to mill the rotors, and you need to worry about those wide *** 300zx calipers fitting under your wheels (which is a major issue many times, they stick way out). so either way you go takes some modification and what not. you don't need any rings if you use rotors from another nissan. you only need rings for things like Mustang Cobra rotors.
Old 04-13-2008, 10:36 PM
I'm needing a caw
Jeff92se's Avatar
Or run the J/Q calipers w/ the 13" Cobra rotors. . I sell the brackets but no longer require the rings if you by Automax's redrilled units.
No grinding of rotors or caliper mounts. It DOES require about 10mm more wheel clearance (width) to run and you need 17" or larger wheels
http://forums.maxima.org/showthread.php?t=351406 13" rotor, j/Q caliper upgrade.
Contact me if you want the brackets ($60 shipped)
Jeff92se is offline
Old 04-14-2008, 04:52 AM
All you need to do is mill 3 mm on the diameter. 6-8mm is way too much.
Old 04-14-2008, 03:25 PM
SLOW
Nealoc187's Avatar
You are incorrect.
3-4mm is off the radius - that means 6-8mm off the diameter (radius x 2 = diameter) I've done that swap, I know what's involved. just 3mm off the diameter is not sufficient.
Old 04-14-2008, 03:36 PM
2nd Gen Boostinator
Big_E-Dog's Avatar
i can get you calipers,rotors, pads comlpete used setup for 150 shipped if anyone is interested. wont have to redrill holes and stuff just slap em on.
from what i heard i thought that the j30 calipers were bigger than the q45. oh well jsut let us kno what you did prolly post some pics so other ppl can see.
Big_E-Dog is offline
Old 04-14-2008, 10:05 PM
aporozco's Avatar
can i just put 300zxtt rotors, calipers onto my car? not the bbk. with the same mods for the j30 calipers?
aporozco is offline
Old 04-14-2008, 10:18 PM
I'm needing a caw
Jeff92se's Avatar
With either the Z or Q/J calipers, the rotor milling is the same. If you aren't using my brackets.
Jeff92se is offline
Old 04-14-2008, 10:28 PM
aporozco's Avatar
thats awesome. thanks jeff. id get ur brackets but i dont have 17s, and where do they mill rotors?
aporozco is offline
Old 04-14-2008, 10:34 PM
I'm needing a caw
Jeff92se's Avatar
Machine shops usually
Jeff92se is offline
Old 04-15-2008, 05:04 AM
You are incorrect.
Interesting. I got the swap. 3 mm and that is all. Let me explain. J30 rotors, J30 calipers, J30 torque member, and J30 brake pads = 3mm off diameter also I checked the dimensions. You have experience, I have experience. Please don't say I'm wrong when I did it. Also, reading numbers off a ruler is very simple as I'm an airport engineer.
3 mm off the diameter if your going with the above said setup.
Old 04-15-2008, 05:55 AM
dralucard's Avatar
are there any benefits to using the J30 rotors vs the stock max rotors? i ask because i did my brakes last year and now want to upgrade w/ the J30 calipers. just don't want to buy another set of rotors. thanks.
dralucard is offline
Old 04-15-2008, 09:02 AM
The j30 rotors are thicker than the Maxima. If I recall its 25mm
Old 04-15-2008, 09:18 AM
SLOW
Nealoc187's Avatar
Interesting - when I did the swap we had to go much more than 3mm off the diameter as stated. I bet that means there are perhaps some slight differences in the caliper shape between different J30 model years.
Old 11-10-2008, 09:42 PM
Blackwind's Avatar
if you can still do this let me know.
Blackwind is offline
aw11power
10-10-2021 04:57 AM
04-16-2020 05:15 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Pied
09-26-2015 03:29 PM
Quick Reply: Q45/J30 Caliper Fitting
