doors lock but passenger still opens when locked??????
Old Apr 12, 2008 | 01:00 AM
tallkid2201's Avatar
ok someone please explain this one....and quick.
i dont want anyone to steal my tv and subs
Old Apr 12, 2008 | 08:48 AM
njmaxseltd's Avatar
You need to take to door pannel off and inspect the latch.
Old Apr 12, 2008 | 10:18 AM
and now it locks if you push the inside button all the way down. it opens a little bit but not all the way.
also the alarm is occasionally not affected when you open the door when locked
Old Apr 12, 2008 | 10:40 AM
CRiME's Avatar
oem ftw!
mine does the same thing, but only when the weather is cold... i guess all that it needs is lubrication but I never got around to inspecting it. i just make it a habit of manually locking the door instead of relying on the key fob.
Old Apr 12, 2008 | 11:07 AM
BLACKonBLACK98's Avatar
Former Vendor
sounds like your rods are off. just because the actuator works doen't mean the latch has moved. take the panel off and check the linkage.
Old Apr 12, 2008 | 11:23 AM
BlkMaxNCa's Avatar
Is ur key fob batteries good, cuz if u need to change the battery that will make it act up, i had the same problem at times........
Old Apr 12, 2008 | 01:22 PM
MAXIMAK99's Avatar
My Max does the same thing in cold weather. I've been to lazy to take the panel off and look at things. I just manually lock it when it's cold out, not a big deal to me since it only happens when it's cold out.
Old Apr 12, 2008 | 03:32 PM
took the panel off and the rods move but dont fully click into locking place. so i pushed it over a little bit and it worked put everything back together and now it doesnt work again......so back off with the panel we go
Old Apr 12, 2008 | 05:09 PM
so it turned out to be the locking rod... i took it out and now it works. only problem is you cant lock the door from the passenger side door anymore but honestly, who has friends nice enough to lock your car when you have a key fob.
johnaschon
Sep 14, 2015 04:29 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
Hailstatejig
Sep 2, 2015 06:52 AM
