Does RSB point out the lack of alignment in the wheels?
Re: Does RSB point out the lack of alignment in the wheels?
Originally posted by DARTHSWAN
Question is the subject.
K
K
K
K
Only the lack of alignment inherent in all straight axle rearends which means that while the outside wheel (while cornering) has optimum camber the inside wheel now has too much negative camber as a direct result of it. This means a lousy contact patch with the ground. This is why everything short of a truck nowadays has independant rear suspension (and Nissan should be slapped). A sway bar helps minimize this only by lessening the effect (while reducing body roll) - it does nothing to change the alignment of one wheel vs. the other. So the RSB's (or FSB if applicable) function is to minimize body roll - which in turn improves grip.
Other than that, I'm not sure what you're asking...
Not really. My alignment was off a while back and I added RSB. It was still off and nothing changed really. Just let go of the steering wheel while doing straight down a road, if it veers a little left or right, then u need to get an alignment. RSB really doesn't change anything, especially since it is in the back and you only align the front two wheels
I was talking about the effect while cornering in relation to the road. The sway bar does nothing to change the alignment of the rear wheels in relation to each other. Nothing is adjustable on the rear (toe, camber, caster...).
bbsitum
Sep 11, 2015 04:55 PM
