can I fit 6inch speakers?
Re: can I fit 6inch speakers?
Originally posted by vteckilla
I have a component set from my prelude from kove audio
that use;s a 6inch mid bass an I was wondering if they will
fit in the front door pods of my 95 maxima.
thanks in advance.
thanks in advance.
Originally posted by nismo240sx
whats the mounting depth...its kinda important, cuz id like to put shallow 8" midbasses in there...and i wanna know how much im gonna have to build out the door...
thanx,
eric
thanx,
eric
Connection
I don't know if the door speakers are the same, but when I did the rears the connection brackets are kind of strange, so you might have to bend the leads in or do tap the lines, something like that, because soldiering is probably not a good idea. The brackets resemble fan connectors n a motherboard, but are a bit tougher and lock in place.
I don't know if they're standard, but it could be a small problem.
Best of luck with your install, though.
I assume if your putting components in, your putting in a new head nit and amp?
So the wiring shouldn't be a problem (If you are putting in those things)...you just need to run the speaker wires yourself from the amp, which you probably already know anyway.
The front speakers in Maxima are in 5" long baffles....so you have 5" of mounting depth.,...more than enough for any component i can think of.
IanS
IanS
sounds like the Kenwood 910DVD headunit, that retails at $2500 so its probably the unit below that! Cost on the 910 is $800 direct from Kenwood, too bad im not installing at my shop anymore, i could have gotten it for $800
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
