Welding Front Core Support
Old Apr 14, 2008 | 04:54 PM
NISSANMAXIMA91's Avatar
First of all before anyone climbs my frame, YES I have been reading up on this and searching ever since i joined the org.
Now, my question is, what is your guys' opinion on welding the front core support vs replacing the bottom support? my 97 isnt terrible, but its at the point that i dont want to stress it too much. couple guys i know work for alcoa and are professional welders, so i feel pretty confident about the welding job, but in my mind its kind of using a band aid when stitches are needed. but whats going to happen is that there will be a new steel plate fabricated that is 20" and wide enough to make the fold up the front, and the old rust cleaned off, motor mount detatched and lowered, new plate put in, remount motor mounts, and weld new plate. i think this would be a lot easier than taking the whole thing apart and new piece put in, but still in my mind its kinda like half assing it here. so what would you guys do?
Old Apr 14, 2008 | 05:41 PM
njmaxseltd's Avatar
After the front end is dissembled, it would only take a body shop an hour or two to cut and weld in a new OE part. Is all the time spend to fabricate an a/m part worth it?
Old Apr 14, 2008 | 06:46 PM
kzoosho's Avatar
What is this going to cost you? I went to the dealership and they quoted me 500 to do it and its a oem part. What kinda warranty you get with this?
Old Apr 14, 2008 | 07:07 PM
if i do it myself and replace the part, the part is 116$ plus whatever the welders want (since i know them, it would be minimal), drill bits and time.
to just weld a metal plate on it, i dunno. next to nothin since its scraps from alcoa they are picking up for me.
Old Apr 14, 2008 | 07:22 PM
kzoosho's Avatar
Why not buy the lower support its 160 i think and do it right . its not that much more and you are talking about going threw alot of labor. Do it once and do it right.
Old Apr 14, 2008 | 07:31 PM
yea, thats the way im leaning towards. i might as well just pull the damn thing and do it right.
any other input is appreciated, and thanks from those who have already chipped in
NM91
Old Apr 14, 2008 | 09:29 PM
happy4444's Avatar
coulda swore there was a how to on the lower.. not sure tho
Old Apr 15, 2008 | 07:17 AM
alcatranz518's Avatar
There is...
...and in the first thread, you can see I already tried the "weld in" method. I am a good welder, just the fact: If you do not completely remove the rust and treat the area, Rust WILL return. 1 year later it did, and I had to replace the support.
Mine
http://forums.maxima.org/showthread....t=support+core
http://forums.maxima.org/showthread.php?t=404531
Shortyblu's
Old Apr 15, 2008 | 08:58 AM
Nealoc187's Avatar
SLOW
I did a custom lower radiator support on my car. Cut the old rusted piece of crap out of there and put in one that is heavy gauge steel. Much stronger and stiffer (and heavier) than that stamped metal piece of crap that came on the car. If you've got experienced fab guys who can do it, I see no reason not to. Took my fab buddy a couple hours to do the entire thing.
Old Apr 15, 2008 | 09:03 AM
Jeff92se's Avatar
I'm needing a caw
Look up mtrai's thread. He did it the right way and replaced the entire support. I helped him weld in the new one. Alot of work but it's brand new now
Old Apr 15, 2008 | 09:05 AM
BLACKonBLACK98's Avatar
Former Vendor
metal is metal, doesn't matter if it has nissan stamped on it or not. what you would need to do is make sure you remove all the corrosion and properly protected the new metal. i'm fairly sure that doing a patch panel correctly would be the more involved of the two.
Old Apr 15, 2008 | 11:51 AM
njmaxseltd's, kzoosho's and my point. Yeah a custom fabbed one is great, but not for cost and time purposes. Just replace factory with factory the correct way will be most time/ cost efficient.
For strength and rigity, then custom fabbed would be better.
Old Apr 15, 2008 | 11:58 AM
Former Vendor
well its a matter of cost vs. effort. do whichever you have more of.
Old Apr 15, 2008 | 01:47 PM
happy4444's Avatar
def better off replacing it instead of putting a band aid on a bullet hole.
what you guys spray or coat it with after you welded the new one in?? i was thinking of hitting mine with the rubberized undercoat they sell in cans at the auto store. any insight?
Old Apr 15, 2008 | 04:12 PM
well, went to the local nissan dealer this afternoon, and here's what i found out.
lower support = 161.48
2 new bolts = 2.47
2 new bushings = 4.25
the bolts and bushing prices may be reversed, but none the less its the cost per piece. so looking at 175 before tax. im willing to go a little more just to know that its all OEM. im being particular about this because this is the frame were talking about here after all. so, guess ill head out and start tearing her down. i think in the long run ill be at ease more so that with just welding a plate on. because i know the rust will continue to spread with moisture.
just gotta find a way to get 220 out in the garage!
Old Apr 16, 2008 | 08:15 AM
Scruit's Avatar
U wanna try me young boy?
I paid 850 to a bodyshop to get the lower support replaced.
Old Apr 16, 2008 | 08:31 AM
Nopike's Avatar
All the posts I've seen on this subject people talk of covering or rubberizing the new core support so it does not rust. I believe these core supports are rusting because water gets trapped inside the core support. It is not due to rocks or external damage. Adding holes to the bottom of the core support so the water can drain may do more to extend the life of the core support then covering it. .
Old Apr 16, 2008 | 03:55 PM
Does anyone know if the parts from World Parts Express are OEM or are they aftermarket? Shortyblu, how's your support holdin up?
Old Apr 16, 2008 | 04:58 PM
all right. got it stripped down to the support. will probably start drilling out welds here soo. anyone have any idea as to how many there are, and general locations? i have found most of them, but dont want to drill out unneccesary welds. my main concern is are there any by the condensor? im leaving everything in the car. condensor, radiator, and for now PS cooler. thats easy enough that if i have to ill take it out.
Old Apr 16, 2008 | 05:23 PM
shortyblu95's Avatar
my support is GREAT! and yes world parts express is OEM nissan parts only. Have fun drilling those welds out, omfg did it suck!!! Trust me there hidden everywhere and some you cant really get a drill bit to so you need to pry and rip the metal away. You should get the point after you cant remove it when you think you got every one. Theres plenty of info on a few threads around about these things being replaced. Youll be tasting metal and or rust by the time your done, thats for sure.
Old Apr 17, 2008 | 11:40 AM
Tfvesquire's Avatar
Glad to hear more people are attempting this PITA project.
For the squeemish, I still offer this repair in the Western Chicago Suburbs for $250.00 labor. The last time I called in for the lower core support price it was listed at $125.00 and $17.00 shipping, but prices must have gone up. BTW, if your bolts and bushings are not all rusted or torn up, you can safely reuse them.
See my thread in the Midwest US forum, in the installers section....
Ted
Old Apr 17, 2008 | 01:39 PM
Do u pay vendor fees? Dont want to be rude but it gets old each thread that invloves core support your in saying the same thing. If they search they can find you easy enough without reposting it over and over.
Old Apr 24, 2008 | 11:21 PM
KRRZ350's Avatar
Man I just finished my 4th one today, they're really not bad at all and it takes way longer to weld a brace in there if you want it as good or better than the oem peice, I did the one on my '95 this way and allthough it came out better than factory the fabrication got pretty hardcore. Also, you can leave 90% of the parts alone that you wouldn't expect to, except for the radiator only because it's very easy to damage it if the tab on the bottom breaks off, I learned that lesson...... than forgot it...... than learned it again!
Anyways, yeah you can leave in the headlights, a/c condensor, etc etc. Pretty much the splasjsheilds, bumpers, "stays" (mounts for the bumper reinforcment, aka the real bumper), and radiator will need to come out and the rest can stay, even the power steering cooler. You just have to get creative with tool usage to get the very few lengthwise pinch welds because you can't drill at an angle.
Old Apr 25, 2008 | 05:37 AM
what tab are you talking about? im getting ready to drill the welds out on mine to drop it this weekend. i dont want to break something i dont have too.
Old Apr 25, 2008 | 05:39 AM
maybe the alignment tabs on the bottom of the rad? I just bungy corded mine up and went at it.
Old Apr 25, 2008 | 05:58 AM
KRRZ350's Avatar
^ Yup exactly, hummm bungee cord, I like that idea.
Old Apr 25, 2008 | 09:02 AM
yea, i was going to tie it up so nothin fell out on me. ie the radiator and condensor. that should do, right>
Old Apr 25, 2008 | 10:04 AM
yea its a good idea to tie or bungy the radiator up. The condensor doesnt really matter because its got hard lines so its not like it will go anywhere. Just be careful when your aligning the new core support because theres also tabs on that, that need to line up with holes on the support.
Old Apr 25, 2008 | 10:14 AM
clint240sx's Avatar
Have it welded! I had my car welded just like 2 days ago! it looks great! if your car is worth keeping, by all means do it, its the hardest part of the front end, but it can def. be done
Old Apr 25, 2008 | 10:29 AM
yea, i noticed those and was aware of alignment. are the tabs on the radiator the same setup?
i didnt mean tie the front end on. that would be a death wish! yes. its going to be professionally welded when i get the new aligned up.
Old Apr 25, 2008 | 04:24 PM
clint240sx's Avatar
ohhh ok my bad. I wrecked mine pretty bad and im havin most of the front end welded with a different front clip.
Old May 17, 2008 | 06:20 PM
hey guys, instead of starting a new thread, ill just use my old one, but after about 2 weeks of dealing with world parts express and DHL, the first supprot they sent got damaged in shipping and just got the new one yesterday. Question is, how do you get the damn welds off the sides on the inside, facing the condensor? im guessing sawzall is the best, but i dont want to damage any of the metal i need to keep with the saw. Is it the best way, or the easiest way. i got 4 out of the six drilled and freed up, but there are 2 left the the drill wont stay because its too agressive of an angle. Im only asking because i diont have a sawzall readily available. any thoughts?
Old May 17, 2008 | 07:51 PM
KRRZ350's Avatar
Yeah I used a sawzall last time, in the past I've used a dremel with a cut-off wheel (<---indespensible tool) I know EXACTLY what two welds you're talking about.
Old May 17, 2008 | 08:50 PM
genius. thanks man. never thought to take a cut off wheel in there and grind on the weld just enough for what i need. better still i could take an air grinder and get it even faster. ( i know. i have and air-compressor and tools, but no sawzall. strange aint it??)
itll be monday and after, but ill keep y'all posted. . .
Old May 19, 2008 | 08:23 PM
ALL RIGHT!!!!!!!!!!! I'm kinda on an accomplishment high right now, BUT ITS OFF!!!! ITS OFF!!! And man, im tired too. Overall, 8 hrs over 3 days (took my time as to not screw anything up and to make sure i got ALL the welds), only the original 4 drill bits i started with, air compressor and air grinder, and drilling/grinding 32 welds on each side of the car, so 64 total, and really, 128 cuz i drilled pilots as well. so for those who want an exact count, there are 64 welds that have to be drilled total. I'll be cleaning and grinding some more the rest of the week to prep it for welding so if all goes well, i could have it back driveable next week!
Oh, get this, I DIDNT HAVE TO USE A SAWZALL!!!!!!!!
Thanks for the help everyone, but im sure its not over yet, but who knows.
Oh, before i forget, it is suggested to disconnect the ECU before welding on it, right? I'll search to find out how if i need to disconnect it.
NM91
Old May 21, 2008 | 08:10 PM
Bump.
Anyone on the ECU?
Old Jun 1, 2008 | 05:48 AM
jaymemaurice's Avatar
ECU being un-plugged = http://forums.maxima.org/showpost.ph...&postcount=103
Old Jun 1, 2008 | 06:01 AM
I brought my new 97 (up to 3 maxima's now) to Crappy Tire for the Ontario provincial safety... and they failed me for the rust on my lower rad support... and mine wasn't as bad as half the photos here.
Mechanic said he wanted it replaced, not repaired... and I plan on having it done within the 10 day re-inspection time as to not lose my $90. He also went all **** and picked out a tiny crack in the tail light lens and a lack of battery strap (although its clipped into the tray??).
For all thoes who think it's rotting because the moisture not getting out from the hollows... what about stuffing it full of expandable foam and making it solid?!
I am thinking of doing that...
AcuraLegend
Oct 17, 2016 08:47 PM
kmitchel
Oct 30, 2015 10:12 AM
dvcamp
Sep 18, 2015 10:17 AM
jfl330
Sep 4, 2015 01:44 PM
